メインコンテンツにスキップ
はじめに
Make sure the power cord is not plugged in and that the device is powered completely off before you begin. Before making any hardware changes to this laptop, make sure the battery is completely removed. This will make repair safer for both you and your laptop.
パーツ
パーツは指定されていません。
  1. Use a PH000 screwdriver to unscrew the eleven 4mm Phillip head screws located on the back panel. Use a PH000 screwdriver to unscrew the eleven 4mm Phillip head screws located on the back panel.
    • Use a PH000 screwdriver to unscrew the eleven 4mm Phillip head screws located on the back panel.
  2. Using the iFixit opening tool, pry open and remove the back cover of the laptop.
    • Using the iFixit opening tool, pry open and remove the back cover of the laptop.
    • Be gentle when applying force to the cover.
  3. MacBook Battery 修理キット
    最低価格 $69.99
    Buy Now
    最低価格 $69.99
    Buy Now
  4. Use a PH000 screwdriver to unscrew the four 3.5mm Philips head screws located on the battery. Use a PH000 screwdriver to unscrew the four 3.5mm Philips head screws located on the battery.
    • Use a PH000 screwdriver to unscrew the four 3.5mm Philips head screws located on the battery.
  5. Disconnect the port connecting the battery and the motherboard and then remove. Disconnect the port connecting the battery and the motherboard and then remove.
    • Disconnect the port connecting the battery and the motherboard and then remove.
まとめ
ある他の人がこのガイドを完成しました。
Stephanie Henry
メンバー登録日: 2018年10月02日
870 ポイント
5のガイドは作成済み
チーム
Eastern Washington University, Team S2-G6, Munoz Fall 2018 Eastern Washington University, Team S2-G6, Munoz Fall 2018人のメンバー
EWU-MUNOZ-F18S2G6
5 メンバー
5のガイドは作成済み
コメント1件
We have a CD player on our laptop. Do we have to do something special with it?
ellenfk91 - 返信
コメントを追加する
統計データを表示:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 50
今までの合計 500
