メインコンテンツにスキップ
HP Pavilion 15-ca2073cl Motherboard Replacement
必要な工具と部品
  1. HP Pavilion 15-ca2073cl Motherboard  Replacement, Back Cover: 手順 1、 1の画像 1
    • Before beginning, make sure the laptop is completely turned off by pressing the off button and waiting for the screen to turn black.
    • Flip the laptop over.
    • Remove all the 6.5mm screws (black) and the 4.8mm long screws (silver) using the Phillips #00 screwdriver.
  2. HP Pavilion 15-ca2073cl Motherboard  Replacement: 手順 2、 2の画像 1 HP Pavilion 15-ca2073cl Motherboard  Replacement: 手順 2、 2の画像 2
    • Use an iFixit opening tool to wedge in between the case and the body of the laptop.
    • Start from the front and work down both sides, disconnecting clips.
    • Remove the bottom case from the body.
  3. HP Pavilion 15-ca2073cl Motherboard  Replacement, Battery: 手順 3、 2の画像 1 HP Pavilion 15-ca2073cl Motherboard  Replacement, Battery: 手順 3、 2の画像 2
    • Remove six 4.8mm screws (silver) using the Phillips #00 screwdriver.
  4. HP Pavilion 15-ca2073cl Motherboard  Replacement, Motherboard: 手順 4、 2の画像 1 HP Pavilion 15-ca2073cl Motherboard  Replacement, Motherboard: 手順 4、 2の画像 2
    この手順で使用する道具:
    購入する
    • Remove the screws surrounding the motherboard using the Phillips #00 screwdriver.
    • Dismount the power supply ribbon cable by lifting the cable lock and pulling the cable with the flat-tipped tweezers.
    • Gently remove and disconnect the two display ribbon cables located at the top right corner of the moother board.
    • Disconnect the keyboard cable next to the power supply cable.
    • Disconnect the disc and hard drive cables.
  5. HP Pavilion 15-ca2073cl Motherboard  Replacement: 手順 5、 1の画像 1
    • Using the flat-tipped tweezers, remove the cable wrapping around the left fan connecting to the mother board.
  6. HP Pavilion 15-ca2073cl Motherboard  Replacement: 手順 6、 1の画像 1
    • Remove the three Phillips #00 screws surrounding the fans.
    • Remove the cables connecting the fans to the motherboard.
    • Gently lift the fans out of place.
  7. HP Pavilion 15-ca2073cl Motherboard  Replacement: 手順 7、 2の画像 1 HP Pavilion 15-ca2073cl Motherboard  Replacement: 手順 7、 2の画像 2
    • Using the spudger, begin to pry all ports connected to the motherboard away from the shell of the laptop.
    • Using the spudger, gently pry the motherboard up and out.
終わりに
作成者
2人の作成者と共同で作成されました。
Clarence Droze
メンバー登録日: 02/20/20
109 ポイント
1ガイドが承認済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 16
今までの合計 954
