メインコンテンツにスキップ
HP Pavilion 15-bk020wm Touchpad Replacement
必要な工具と部品
  1. HP Pavilion 15-bk020wm Touchpad Replacement, Keyboard Cover: 手順 1、 2の画像 1 HP Pavilion 15-bk020wm Touchpad Replacement, Keyboard Cover: 手順 1、 2の画像 2
    • Before you begin, turn the laptop off and unplug it from the power source.
    • Remove the 4 computer feet. (Our device didn't have these; they can be taken off with a plastic spudger.)
    • Remove the two screw cover strips.
    • Remove the two screw cover plugs.
    • Unscrew all 12 screws (size: Phillips M2.5×7.0 ) from the bottom of the computer.
  2. HP Pavilion 15-bk020wm Touchpad Replacement: 手順 2、 3の画像 1 HP Pavilion 15-bk020wm Touchpad Replacement: 手順 2、 3の画像 2 HP Pavilion 15-bk020wm Touchpad Replacement: 手順 2、 3の画像 3
    • Turn the computer over to the front.
    • Open the laptop.
    • Use a plastic pry tool to pry up the keyboard cover near the hinge on both the right and left side, and work your way towards the touchpad.
  3. HP Pavilion 15-bk020wm Touchpad Replacement: 手順 3、 1の画像 1
    • Tilt the keyboard cover up slightly.
    • Do not fully remove the keyboard, as it is still attached to the laptop by some cables.
  4. HP Pavilion 15-bk020wm Touchpad Replacement, Touchpad: 手順 4、 2の画像 1 HP Pavilion 15-bk020wm Touchpad Replacement, Touchpad: 手順 4、 2の画像 2
    • After taking the keyboard cover off of the device, flip it over and locate the purple and white cable.
    • Using the plastic opening tool, flip the ZIF connector open and detach the touchpad cable.
  5. HP Pavilion 15-bk020wm Touchpad Replacement: 手順 5、 3の画像 1 HP Pavilion 15-bk020wm Touchpad Replacement: 手順 5、 3の画像 2 HP Pavilion 15-bk020wm Touchpad Replacement: 手順 5、 3の画像 3
    • Unscrew the three screws at the bottom of the touchpad using the #00 Phillips screwdriver.
    • Life the bottom security piece off of the touchpad.
    • Unscrew the three top screws using the same #00 Phillips screwdriver.
  6. HP Pavilion 15-bk020wm Touchpad Replacement: 手順 6、 1の画像 1
    • Using the plastic opening tool, lift the touchpad off of the keyboard cover.
終わりに
作成者
1人の作成者と共同作成されました。
Meshayla Block
メンバー登録日: 06/28/17
437 ポイント
3のガイドは作成済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 26
今までの合計 7,232
