はじめに
This replacement guide will show how to replace the hard drive of an HP Pavilion 15-b109wm. This process might be needed in case the laptop has a faulty hard drive. This guide will take between 20-35 minutes, if done correctly. Remember to take your time and do the steps correctly and gently to avoid parts breakage.
For this guide you will need a heavy-duty spudger, a JIS driver set and an iFixtit opening tool. Some parts of this guide require some force to pop open, be careful not to brake or damage any parts when applying force.
必要な工具と部品
この手順で使用する道具:Heavy-Duty Spudger$4.99
Turn the device onto its side.
Using a heavy duty spudger, gently disengage the keyboard.
To reassemble your device, follow the instructions in reverse order.
2 の人々がこのガイドを完成させました。
