必要な工具と部品
Turn the laptop upside down with the base of the laptop facing you.
Remove the grippers positioned at the top right and top left of the laptop to access the two additional screws.
Use a 1.5mm Hex screwdriver to remove twelve 10mm screws.
Using the Jimmy, create a separation between the keyboard and bottom panel.
Slide around the body of the panel until the separation is big enough for you to use your fingers.
Separate the keyboard and bottom panel.
Orient the base of the laptop with the base facing away from you.
With you index finger and thumb, position your thumb underneath both latches on either side of the RAM and squeeze outwards.
Simultaneously, use your index finger to push the RAM sticks towards you.
The RAM stick will release and pop up and out.
