はじめに
If your HP pavilion 15-ay041wm laptop keyboard is not functioning properly, this guide details how to install a replacement keyboard. Ensure that the laptop is unplugged before starting this repair.
必要な工具と部品
Turn the laptop upside down with the base of the laptop facing you.
Remove the grippers positioned at the top right and top left of the laptop to access the two additional screws.
Use a 1.5mm Hex screwdriver to remove twelve 10mm screws.
Using the Jimmy, create a separation between the keyboard and bottom panel.
Slide around the body of the panel until the separation is big enough for you to use your fingers.
Separate the keyboard and bottom panel.
