メインコンテンツにスキップ
HP Pavilion 15-au123cl Hard Drive Replacement
必要な工具と部品
  1. HP Pavilion 15-au123cl Hard Drive Replacement, Battery: 手順 1、 1の画像 1
    • Make sure the laptop is off and unplugged before starting.
    • Using the plastic opening tool, remove the top rubber feet on the back panel as it hides one of the screws we will be removing.
  2. HP Pavilion 15-au123cl Hard Drive Replacement: 手順 2、 2の画像 1 HP Pavilion 15-au123cl Hard Drive Replacement: 手順 2、 2の画像 2
    • Using a PH0 screwdriver, unscrew the ten 4.4mm Phillips head screws located on the back panel.
  3. HP Pavilion 15-au123cl Hard Drive Replacement: 手順 3、 2の画像 1 HP Pavilion 15-au123cl Hard Drive Replacement: 手順 3、 2の画像 2
    • Using the plastic opening tool, remove the back cover of the laptop.
    • It is recommended that you start with a corner and run the tool throughout the edges of the cover.
    • Be sure not to bend the cover by applying too much force.
  4. HP Pavilion 15-au123cl Hard Drive Replacement: 手順 4、 2の画像 1 HP Pavilion 15-au123cl Hard Drive Replacement: 手順 4、 2の画像 2
    • Using a PH0 screwdriver, unscrew the two 3.8mm PH0 Phillips head screws that hold the battery in place.
  5. HP Pavilion 15-au123cl Hard Drive Replacement: 手順 5、 3の画像 1 HP Pavilion 15-au123cl Hard Drive Replacement: 手順 5、 3の画像 2 HP Pavilion 15-au123cl Hard Drive Replacement: 手順 5、 3の画像 3
    • Carefully disconnect the cable connecting the top of the battery and remove the battery.
  6. HP Pavilion 15-au123cl Hard Drive Replacement, Hard Drive: 手順 6、 3の画像 1 HP Pavilion 15-au123cl Hard Drive Replacement, Hard Drive: 手順 6、 3の画像 2 HP Pavilion 15-au123cl Hard Drive Replacement, Hard Drive: 手順 6、 3の画像 3
    • The hard drive is located at the lower left area of the motherboard.
    • Using the spudger, lift the white latch holding the hard drive cable in place.
  7. HP Pavilion 15-au123cl Hard Drive Replacement: 手順 7、 1の画像 1
    • Using the opening tool, lift the hard drive out of the motherboard.
  8. HP Pavilion 15-au123cl Hard Drive Replacement: 手順 8、 2の画像 1 HP Pavilion 15-au123cl Hard Drive Replacement: 手順 8、 2の画像 2
    • Remove the hard drive cable from the hard drive.
  9. HP Pavilion 15-au123cl Hard Drive Replacement: 手順 9、 2の画像 1 HP Pavilion 15-au123cl Hard Drive Replacement: 手順 9、 2の画像 2
    • Pull off the plastic wedges on both sides of the hard drive.
終わりに
10 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Mohammad Gardezi
メンバー登録日: 10/17/17
1,420 ポイント
6のガイドは作成済み
チーム
USF Tampa, Team S13-G3, Cagle Fall 2017 USF Tampa, Team S13-G3, Cagle Fall 2017人のメンバー
USFT-CAGLE-F17S13G3
2 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 54
今までの合計 6,586
