はじめに
This guide will show you how to open your device and remove the hard drive. Whether you have a failed hard drive or simply want to upgrade to more capacity this guide will take you through the necessary steps involved in replacement.
必要な工具と部品
With the battery removed, remove both black plastic covers with a plastic opening tool. Unscrew both 7.5 mm screws from the tabs, using a PH1 screw driver. Using a plastic opening tool, pry off both covers.
3 の人々がこのガイドを完成させました。
