メインコンテンツにスキップ
HP Pavilion 15-ab165us Battery and Back Cover Replacement
必要な工具と部品
  1. HP Pavilion 15-ab165us Battery and Back Cover Replacement, Battery and Back Cover: 手順 1、 2の画像 1 HP Pavilion 15-ab165us Battery and Back Cover Replacement, Battery and Back Cover: 手順 1、 2の画像 2
    • Flip the computer over so that the bottom cover is facing you.
    • Slide the two locks to the "unlock" position and remove the battery.
  2. HP Pavilion 15-ab165us Battery and Back Cover Replacement: 手順 2、 3の画像 1 HP Pavilion 15-ab165us Battery and Back Cover Replacement: 手順 2、 3の画像 2 HP Pavilion 15-ab165us Battery and Back Cover Replacement: 手順 2、 3の画像 3
    • Remove the two 8mm screws underneath with a Phillips #1 screwdriver.
    • Use a plastic opening tool to remove the plastic feet.
  3. HP Pavilion 15-ab165us Battery and Back Cover Replacement: 手順 3、 3の画像 1 HP Pavilion 15-ab165us Battery and Back Cover Replacement: 手順 3、 3の画像 2 HP Pavilion 15-ab165us Battery and Back Cover Replacement: 手順 3、 3の画像 3
    • Remove the two plastic tabs with a metal spudger.
  4. HP Pavilion 15-ab165us Battery and Back Cover Replacement: 手順 4、 1の画像 1
    • Remove the sixteen 8mm screws that hold the bottom cover with a Phillips #1 screwdriver.
  5. HP Pavilion 15-ab165us Battery and Back Cover Replacement: 手順 5、 1の画像 1
    • Pull the Optical Drive out.
  6. HP Pavilion 15-ab165us Battery and Back Cover Replacement: 手順 6、 1の画像 1
    • Remove the 3mm screws that were hidden under the Optical Drive with a Phillips #0 screwdriver.
  7. HP Pavilion 15-ab165us Battery and Back Cover Replacement: 手順 7、 2の画像 1 HP Pavilion 15-ab165us Battery and Back Cover Replacement: 手順 7、 2の画像 2
    • Flip the computer back over.
    • Use a plastic opening tool to release the clips holding the keyboard section in place.
  8. HP Pavilion 15-ab165us Battery and Back Cover Replacement: 手順 8、 1の画像 1
    • Close the lid and pull the screen and keyboard section up and away from the disconnected bottom cover.
    • The hard drive is NOT screwed into place on the underside of the keyboard section.
終わりに
10 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Dillon Hubble
メンバー登録日: 10/20/17
653 ポイント
3のガイドは作成済み
チーム
UW Tacoma, Team S1-G2, Rose Fall 2017 UW Tacoma, Team S1-G2, Rose Fall 2017人のメンバー
UWT-ROSE-F17S1G2
5 メンバー
14のガイドは作成済み
1 Guide Comment
Where can i buy the case? I couldn’t anywhere online??
Model - HP Pavilion 15 8th gen B&O
Jackson Beno - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 23
過去 30 日: 87
今までの合計 66,495
