はじめに
Using this guide, you can replace the motherboard in your HP Pavilion 14-bk061st laptop.
The motherboard is the central connection between all the components of a computer. A faulty motherboard can lead to the whole computer failing so it is important to keep good care of all the components in your PC.
必要な工具と部品
Remove the three 5.7 JIS #1 screws from the bottom of the laptop.
Remove the two 6.7mm JIS #1 screws from underneath the feet of the laptop close to the exhaust vent.
この手順で使用する道具:Halberd Spudger$2.99
Use the hook end of the Halberd spudger to pull back the clamps holding the card in place.
Disconnect the two Wi-Fi and Bluetooth antenna wires by gently pulling them away from the board.
3 の人々がこのガイドを完成させました。
