メインコンテンツにスキップ
HP Pavilion 14-b120dx CPU Cooling Fan Replacement
必要な工具と部品
  1. HP Pavilion 14-b120dx CPU Cooling Fan Replacement, Battery: 手順 1、 1の画像 1
    • Power down the laptop and detach the charging cord (failure to do so can result in electrical shock).
  2. HP Pavilion 14-b120dx CPU Cooling Fan Replacement: 手順 2、 3の画像 1 HP Pavilion 14-b120dx CPU Cooling Fan Replacement: 手順 2、 3の画像 2 HP Pavilion 14-b120dx CPU Cooling Fan Replacement: 手順 2、 3の画像 3
    • Flip the laptop upside down so that the bottom is facing you.
    • Push the slide on the right toward the center of the laptop, releasing the battery latch.
    • Lift the battery up and away from the laptop.
  3. HP Pavilion 14-b120dx CPU Cooling Fan Replacement, Keyboard: 手順 3、 3の画像 1 HP Pavilion 14-b120dx CPU Cooling Fan Replacement, Keyboard: 手順 3、 3の画像 2 HP Pavilion 14-b120dx CPU Cooling Fan Replacement, Keyboard: 手順 3、 3の画像 3
    • Insert the plastic opening tool between the keyboard and the palm rest.
    • Pry upwards until the keyboard section detaches from the laptop.
    • Repeat this around the edge of the entire keyboard.
    • Sections will make loud snapping noises as they detach from the palm rest - this is normal.
  4. HP Pavilion 14-b120dx CPU Cooling Fan Replacement: 手順 4、 2の画像 1 HP Pavilion 14-b120dx CPU Cooling Fan Replacement: 手順 4、 2の画像 2
    • Lift the keyboard slowly up until the connecting cable is exposed.
    • Carefully lift the flap on the ZIF connector using a fingernail or plastic opening tool. This will release the cable.
    • Detach the cable.
  5. HP Pavilion 14-b120dx CPU Cooling Fan Replacement, Palm Rest: 手順 5、 2の画像 1 HP Pavilion 14-b120dx CPU Cooling Fan Replacement, Palm Rest: 手順 5、 2の画像 2
    • Unscrew the 10 6.0 mm screws under the keyboard housing with a Philips #0 head screwdriver.
  6. HP Pavilion 14-b120dx CPU Cooling Fan Replacement: 手順 6、 3の画像 1 HP Pavilion 14-b120dx CPU Cooling Fan Replacement: 手順 6、 3の画像 2 HP Pavilion 14-b120dx CPU Cooling Fan Replacement: 手順 6、 3の画像 3
    • Insert the plastic opening tool into the seam between the palm rest and the laptop.
    • Pry upwards until the palm rest separates from the laptop.
    • Repeat this process around the entire computer.
    • These steps will be similar to the ones you took to remove the keyboard. Again, you will hear snapping noises.
  7. HP Pavilion 14-b120dx CPU Cooling Fan Replacement: 手順 7、 1の画像 1
    • Lift upwards to remove the palm rest.
  8. HP Pavilion 14-b120dx CPU Cooling Fan Replacement, CPU Cooling Fan: 手順 8、 2の画像 1 HP Pavilion 14-b120dx CPU Cooling Fan Replacement, CPU Cooling Fan: 手順 8、 2の画像 2
    • Locate the fan in the upper left hand corner of the laptop.
    • Remove the cable connecting the fan to the motherboard.
    • Be sure not to damage the motherboard or the connecting cable. Carefully apply force to remove the cable.
  9. HP Pavilion 14-b120dx CPU Cooling Fan Replacement: 手順 9、 2の画像 1 HP Pavilion 14-b120dx CPU Cooling Fan Replacement: 手順 9、 2の画像 2
    • Unscrew the 3 6.0 mm screws holding the fan with a Phillips #0 head screwdriver.
  10. HP Pavilion 14-b120dx CPU Cooling Fan Replacement: 手順 10、 1の画像 1
    • Remove the fan by pulling upward and to the right.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Erin Lavalla
メンバー登録日: 10/18/16
458 ポイント
4のガイドは作成済み
チーム
UMass Dartmouth, Team 4-4, Catania Fall 2016 UMass Dartmouth, Team 4-4, Catania Fall 2016人のメンバー
UMASSD-CATANIA-F16S4G4
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 15
今までの合計 1,280
