メインコンテンツにスキップ
HP Pavilion 11-n010dx Ram Replacement
必要な工具と部品
  1. HP Pavilion 11-n010dx Ram Replacement, Battery: 手順 1、 2の画像 1 HP Pavilion 11-n010dx Ram Replacement, Battery: 手順 1、 2の画像 2
    • Use the nylon spudger to remove the rubber pads near the hinge of the screen, then remove the screws under the pads.
    • Use the Phillips #0 to remove four 9mm screws.
    • Use the Phillips #0 to remove seven 6mm screws.
  2. HP Pavilion 11-n010dx Ram Replacement: 手順 2、 3の画像 1 HP Pavilion 11-n010dx Ram Replacement: 手順 2、 3の画像 2 HP Pavilion 11-n010dx Ram Replacement: 手順 2、 3の画像 3
    • Use the nylon spudger to pry the back casing near the hinges for the screen.
    • Continue to pry along the edge of the back case until the back is ready to be removed.
    • Careful when beginning to remove the case. There is a cable attached between the bottom case and the motherboard that must be properly disconnected.
  3. HP Pavilion 11-n010dx Ram Replacement: 手順 3、 2の画像 1 HP Pavilion 11-n010dx Ram Replacement: 手順 3、 2の画像 2
    • Use the blue plastic opening tool to lift up on the white tab that is holding the cable in place on the motherboard.
    • Now carefully pull the cable out of place and remove the entire back casing.
  4. HP Pavilion 11-n010dx Ram Replacement: 手順 4、 1の画像 1
    • Remove the five 6mm screws that hold the battery in place using the Phillips #0.
  5. HP Pavilion 11-n010dx Ram Replacement: 手順 5、 2の画像 1 HP Pavilion 11-n010dx Ram Replacement: 手順 5、 2の画像 2
    • Use the nylon spudger to pry away the blue/white wire that is positioned near your battery.
  6. HP Pavilion 11-n010dx Ram Replacement: 手順 6、 2の画像 1 HP Pavilion 11-n010dx Ram Replacement: 手順 6、 2の画像 2
    • Disconnect the battery cable from the motherboard by carefully pulling on the black wire at the point closest to the white tab.
  7. HP Pavilion 11-n010dx Ram Replacement: 手順 7、 1の画像 1
    • Remove the battery from your device.
  8. HP Pavilion 11-n010dx Ram Replacement, Ram: 手順 8、 2の画像 1 HP Pavilion 11-n010dx Ram Replacement, Ram: 手順 8、 2の画像 2
    • Using your fingernails, pull the tabs on either side of the RAM to release the module from its secured spot.
  9. HP Pavilion 11-n010dx Ram Replacement: 手順 9、 2の画像 1 HP Pavilion 11-n010dx Ram Replacement: 手順 9、 2の画像 2
    • Carefully grab and pull to remove the RAM from your device.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Joseph Lintz
メンバー登録日: 09/15/16
915 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 11-5, Blackwell Fall 2016 USF Tampa, Team 11-5, Blackwell Fall 2016人のメンバー
USFT-BLACKWELL-F16S11G5
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 21
今までの合計 751
