はじめに
If the bottom case of your device become cracked or damaged, this guide will show you how to replace it.
必要な工具と部品
Use the nylon spudger to remove the rubber pads near the hinge for the screen. Then remove the screws under the pads.
Use Phillips #0 to remove four 9mm screws.
Use Phillips #0 to remove seven 6mm screws.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
