メインコンテンツにスキップ
HP Pavilion 11 x360 Speakers Replacement
必要な工具と部品
  1. HP Pavilion 11 x360 Speakers Replacement, Remove Screws: 手順 1、 2の画像 1 HP Pavilion 11 x360 Speakers Replacement, Remove Screws: 手順 1、 2の画像 2
    • Use the spudger to pry off the two rubber feet near the hinge of the laptop. This will reveal two hidden 9mm screws.
    • You must remove eleven screws.
    • Four 9mm screws with the PH0 screwdriver.
    • Seven 6mm screws with the PH0 screwdriver.
  2. HP Pavilion 11 x360 Speakers Replacement, Remove Backing: 手順 2、 3の画像 1 HP Pavilion 11 x360 Speakers Replacement, Remove Backing: 手順 2、 3の画像 2 HP Pavilion 11 x360 Speakers Replacement, Remove Backing: 手順 2、 3の画像 3
    • Use the spudger to pry the corners of the laptop near the display hinges.
    • Pry around the seam of the laptop with the plastic opening tool until the backing begins to pull apart.
    • When you lift the bottom cover, there is a cable connected between the motherboard and the bottom cover. Be careful not to pull the cable loose!
  3. HP Pavilion 11 x360 Speakers Replacement, Detach Cable: 手順 3、 2の画像 1 HP Pavilion 11 x360 Speakers Replacement, Detach Cable: 手順 3、 2の画像 2
    • Use the plastic opening tool to lift the white tab up at the connection.
    • Pull the cable outwards.
  4. HP Pavilion 11 x360 Speakers Replacement, Battery: 手順 4、 1の画像 1
    • Remove the four 6mm screws from the battery with the PH0 screwdriver.
  5. HP Pavilion 11 x360 Speakers Replacement: 手順 5、 3の画像 1 HP Pavilion 11 x360 Speakers Replacement: 手順 5、 3の画像 2 HP Pavilion 11 x360 Speakers Replacement: 手順 5、 3の画像 3
    • Use the spudger to pry up the blue/white speaker wires that are routed beside the battery.
  6. HP Pavilion 11 x360 Speakers Replacement: 手順 6、 2の画像 1 HP Pavilion 11 x360 Speakers Replacement: 手順 6、 2の画像 2
    • Remove the battery cable from the motherboard by gently pulling out on the black part of the cable closest to the white tab.
  7. HP Pavilion 11 x360 Speakers Replacement: 手順 7、 2の画像 1 HP Pavilion 11 x360 Speakers Replacement: 手順 7、 2の画像 2
    • Remove the battery.
  8. HP Pavilion 11 x360 Speakers Replacement, Speakers: 手順 8、 3の画像 1 HP Pavilion 11 x360 Speakers Replacement, Speakers: 手順 8、 3の画像 2 HP Pavilion 11 x360 Speakers Replacement, Speakers: 手順 8、 3の画像 3
    • Remove two 6mm screws on each speaker with the PH0 screwdriver.
  9. HP Pavilion 11 x360 Speakers Replacement: 手順 9、 3の画像 1 HP Pavilion 11 x360 Speakers Replacement: 手順 9、 3の画像 2 HP Pavilion 11 x360 Speakers Replacement: 手順 9、 3の画像 3
    • Disconnect the black cable that attaches the speakers to the motherboard by gently pulling the cable outward.
    • Remove the speakers.
終わりに
2 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Natalie
メンバー登録日: 01/22/15
937 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 19-9, Maness Winter 2015 Cal Poly, Team 19-9, Maness Winter 2015人のメンバー
CPSU-MANESS-W15S19G9
4 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 10
今までの合計 1,565
