はじめに
Begin by making sure your device is powered off and unplugged from any power source.
必要な工具と部品
Use the spudger to pry off the two rubber feet near the hinge of the laptop. This will reveal two hidden 9mm screws.
You must remove eleven screws.
Four 9mm screws with the PH0 screwdriver.
Seven 6mm screws with the PH0 screwdriver.
Use the spudger to pry the corners of the laptop near the display hinges.
Pry around the seam of the laptop with the plastic opening tool until the backing begins to pull apart.
Use the plastic opening tool to lift the white tab up at the connection.
Pull the cable outwards.
27 の人々がこのガイドを完成させました。
11件のガイドコメント
exellent and easy steps............but......where do i buy battery.....?
Muy bueno parece facil
Great step by step explanation. Solid pictures!!! Could not have fixed this without your contribution!!!
Purchased this laptop 28/12/2015 and now its just not switching on at all. I will try the repair instructions but I think it should have lasted a bit longer, what ever the problem is. The store where I bought it have checked the cable for me to see if that was the problem and it wasn’t. They wanted £60 to send it off, to find out the issue before anything was even done. The sales assistant said it could be the battery but he said it should have lasted longer. He basically said if its the motherboard you may as well just throw it out. I am sick of paying £100’s out for electrical items that live very short lives. My daughter bought this with her own money that she had been saving. I would not purchase this make of laptop again and where do I get a replacement battery and how much is that likely to be?
