はじめに
A damaged scanner glass will at best produce poor quality images, and at worst damage other parts of the printer or cause injury. Replacing the scanner glass only requires a couple tools and a little patience.
必要な工具と部品
Grasp the scanner lid cover from the front of the device and lift lid all the way up until it stands on its own.
Locate the finger notch on the inside top left half of the bezel (control) panel cover.
Place your index finger in the notch and lift up to unsnap the panel.
Set the panel cover aside.
ある他の人がこのガイドを完成しました。
