メインコンテンツにスキップ
HP Omni 10 Speaker Replacement
必要な工具と部品
  1. HP Omni 10  Speaker Replacement, Battery: 手順 1、 1の画像 1
    • Remove the back cover from the tablet.
    • The cover is securely fastened to the device and may be difficult to remove.
  2. HP Omni 10  Speaker Replacement: 手順 2、 1の画像 1
    • Push the black plastic security flaps into an upward position.
    • Lift the small tab on the security strips up and peel them across the battery. They will be attached via adhesive.
    • Lift the tab on the strip up and pull it across the battery.
    • The orange strip does not fully detach from the tablet like the other three. It will only detach from one side.
  3. HP Omni 10  Speaker Replacement: 手順 3、 1の画像 1
    • Unscrew the ten 3.3 mm screws securing the battery using a 00 Phillip's head screwdriver.
  4. HP Omni 10  Speaker Replacement: 手順 4、 2の画像 1 HP Omni 10  Speaker Replacement: 手順 4、 2の画像 2
    • Unhook the cord from the edge of the battery.
    • Pull the wire circuit out and down.
  5. HP Omni 10  Speaker Replacement: 手順 5、 2の画像 1 HP Omni 10  Speaker Replacement: 手順 5、 2の画像 2
    • Lift the battery up by its edges and remove it carefully. There will be adhesive holding the battery down.
  6. HP Omni 10  Speaker Replacement, Micro Card Reader: 手順 6、 1の画像 1
    • Unscrew the two 3.3 mm screws using a 00 Phillip's head screwdriver.
  7. HP Omni 10  Speaker Replacement: 手順 7、 1の画像 1
    • Lift and remove micro card reader board.
  8. HP Omni 10  Speaker Replacement, Speaker: 手順 8、 1の画像 1
    • Unscrew the four 3.3 mm screws using a 00 Phillip's head screwdriver.
  9. HP Omni 10  Speaker Replacement: 手順 9、 2の画像 1 HP Omni 10  Speaker Replacement: 手順 9、 2の画像 2
    • Pull the black and white wire connector up to disconnect it.
  10. HP Omni 10  Speaker Replacement: 手順 10、 2の画像 1 HP Omni 10  Speaker Replacement: 手順 10、 2の画像 2
    • Pull the red and black wire connector up to disconnect it.
  11. HP Omni 10  Speaker Replacement: 手順 11、 1の画像 1
    • Lift the speaker set out of their sockets.
    • The speakers will also be attached via adhesive. They may be difficult to remove by hand.
  12. HP Omni 10  Speaker Replacement: 手順 12、 1の画像 1
    • Unhook the left speaker's connector wire to fully remove it from the device.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Alex Miller
メンバー登録日: 10/11/16
345 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 1-1, Leahy Fall 2016 USF Tampa, Team 1-1, Leahy Fall 2016人のメンバー
USFT-LEAHY-F16S1G1
3 メンバー
10のガイドは作成済み
コメント 1 件
its order when i will get it please candly I request
Abdul Raheem - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 5
過去 30 日: 13
今までの合計 596
