メインコンテンツにスキップ
HP Omen 15-ax243dx Ventilation Fans Replacement
必要な工具と部品
  1. HP Omen 15-ax243dx Ventilation Fans Replacement, Battery: 手順 1、 2の画像 1 HP Omen 15-ax243dx Ventilation Fans Replacement, Battery: 手順 1、 2の画像 2
    • The rear panel is secured by 10 screws. Using a #00 Phillips Screwdriver, remove the ten 1.2 mm screws.
    • The screwdriver should be inserted at the same angle as the screws.
    • Be sure to keep track of the screws and where they came from. Some only fit in to one spot.
  2. HP Omen 15-ax243dx Ventilation Fans Replacement: 手順 2、 2の画像 1 HP Omen 15-ax243dx Ventilation Fans Replacement: 手順 2、 2の画像 2
    • Insert a plastic opening tool between the rear panel and the top case. Pry the opening tool upwards to separate the top case from the bottom case.
    • Slide the opening tool along the case perimeter to loosen the bottom case.
    • Gently pull the bottom case away from the laptop.
  3. HP Omen 15-ax243dx Ventilation Fans Replacement: 手順 3、 2の画像 1 HP Omen 15-ax243dx Ventilation Fans Replacement: 手順 3、 2の画像 2
    • Remove the four 1.2 mm Phillips #00 screws around the battery.
  4. HP Omen 15-ax243dx Ventilation Fans Replacement: 手順 4、 2の画像 1 HP Omen 15-ax243dx Ventilation Fans Replacement: 手順 4、 2の画像 2
    • Pull the battery cable out from its motherboard socket.
    • Pull parallel to the motherboard, not straight up.
    • Remove the battery.
    • Disconnect the power cord from the battery and transfer it to your replacement battery.
  5. HP Omen 15-ax243dx Ventilation Fans Replacement, Ventilation Fans: 手順 5、 1の画像 1
    • The two ventilation fans are secured with the system by 5 screws. Unscrew these five 1.2 mm screws using the Phillips #0 screwdriver.
    • When removing the screws, use a magnetic screwdriver to prevent the screws from falling behind the motherboard
  6. HP Omen 15-ax243dx Ventilation Fans Replacement: 手順 6、 2の画像 1 HP Omen 15-ax243dx Ventilation Fans Replacement: 手順 6、 2の画像 2
    • After removing all 5 screws, the fans are still connected with the system through 2 cables.
    • Carefully pull the fan cables out of the connectors on the motherboard.
    • Be cautious when pulling by the wires, this can permanently damage the fans beyond repair.
  7. HP Omen 15-ax243dx Ventilation Fans Replacement: 手順 7、 1の画像 1
    • The fans can now be removed from the device.
終わりに
4 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
vangnam
メンバー登録日: 10/19/17
594 ポイント
4のガイドは作成済み
チーム
UMass Dartmouth, Team S6-G7, Rockett Fall 2017 UMass Dartmouth, Team S6-G7, Rockett Fall 2017人のメンバー
UMASSD-ROCKETT-F17S6G7
3 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 19
今までの合計 5,738
