メインコンテンツにスキップ
HP Omen 15-ax243dx Screen Replacement
必要な工具と部品
  1. HP Omen 15-ax243dx Screen Replacement, Battery: 手順 1、 2の画像 1 HP Omen 15-ax243dx Screen Replacement, Battery: 手順 1、 2の画像 2
    • The rear panel is secured by 10 screws. Using a #00 Phillips Screwdriver, remove the ten 1.2 mm screws.
    • The screwdriver should be inserted at the same angle as the screws.
    • Be sure to keep track of the screws and where they came from. Some only fit in to one spot.
  2. HP Omen 15-ax243dx Screen Replacement: 手順 2、 2の画像 1 HP Omen 15-ax243dx Screen Replacement: 手順 2、 2の画像 2
    • Insert a plastic opening tool between the rear panel and the top case. Pry the opening tool upwards to separate the top case from the bottom case.
    • Slide the opening tool along the case perimeter to loosen the bottom case.
    • Gently pull the bottom case away from the laptop.
  3. HP Omen 15-ax243dx Screen Replacement: 手順 3、 2の画像 1 HP Omen 15-ax243dx Screen Replacement: 手順 3、 2の画像 2
    • Remove the four 1.2 mm Phillips #00 screws around the battery.
  4. HP Omen 15-ax243dx Screen Replacement: 手順 4、 2の画像 1 HP Omen 15-ax243dx Screen Replacement: 手順 4、 2の画像 2
    • Pull the battery cable out from its motherboard socket.
    • Pull parallel to the motherboard, not straight up.
    • Remove the battery.
    • Disconnect the power cord from the battery and transfer it to your replacement battery.
  5. HP Omen 15-ax243dx Screen Replacement, Screen: 手順 5、 2の画像 1 HP Omen 15-ax243dx Screen Replacement, Screen: 手順 5、 2の画像 2
    • Unscrew the six 1.2 mm screws connecting the screen to the body using the #00 Phillips screwdriver head.
    • Be cautious of where the screws come out from, some will only fit in the same location.
  6. HP Omen 15-ax243dx Screen Replacement: 手順 6、 3の画像 1 HP Omen 15-ax243dx Screen Replacement: 手順 6、 3の画像 2 HP Omen 15-ax243dx Screen Replacement: 手順 6、 3の画像 3
    • Remove the tape holding the wires down
    • Disconnect the wires from the wifi chip
    • When removing the wires from the wifi chip, be careful to not damage the connectors.
  7. HP Omen 15-ax243dx Screen Replacement: 手順 7、 3の画像 1 HP Omen 15-ax243dx Screen Replacement: 手順 7、 3の画像 2 HP Omen 15-ax243dx Screen Replacement: 手順 7、 3の画像 3
    • Flip the switch up that holds the screen cable in place
    • Lift up and pull back the cable from the insert
  8. HP Omen 15-ax243dx Screen Replacement: 手順 8、 2の画像 1 HP Omen 15-ax243dx Screen Replacement: 手順 8、 2の画像 2
    • Lift the base of the device up to separate the hinges from the body of the device
  9. HP Omen 15-ax243dx Screen Replacement: 手順 9、 1の画像 1
    • Slide the base of the device out from under the hinges
    • The screen can now be replaced
終わりに
作成者
3人の作成者と共同で作成されました。
vangnam
メンバー登録日: 10/19/17
594 ポイント
4のガイドは作成済み
チーム
UMass Dartmouth, Team S6-G7, Rockett Fall 2017 UMass Dartmouth, Team S6-G7, Rockett Fall 2017人のメンバー
UMASSD-ROCKETT-F17S6G7
3 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 35
今までの合計 5,482
