メインコンテンツにスキップ
HP Omen 15-ax243dx Hard-Drive Replacement
必要な工具と部品
  1. HP Omen 15-ax243dx Hard-Drive Replacement, Battery: 手順 1、 2の画像 1 HP Omen 15-ax243dx Hard-Drive Replacement, Battery: 手順 1、 2の画像 2
    • The rear panel is secured by 10 screws. Using a #00 Phillips Screwdriver, remove the ten 1.2 mm screws.
    • The screwdriver should be inserted at the same angle as the screws.
    • Be sure to keep track of the screws and where they came from. Some only fit in to one spot.
  2. HP Omen 15-ax243dx Hard-Drive Replacement: 手順 2、 2の画像 1 HP Omen 15-ax243dx Hard-Drive Replacement: 手順 2、 2の画像 2
    • Insert a plastic opening tool between the rear panel and the top case. Pry the opening tool upwards to separate the top case from the bottom case.
    • Slide the opening tool along the case perimeter to loosen the bottom case.
    • Gently pull the bottom case away from the laptop.
  3. HP Omen 15-ax243dx Hard-Drive Replacement: 手順 3、 2の画像 1 HP Omen 15-ax243dx Hard-Drive Replacement: 手順 3、 2の画像 2
    • Remove the four 1.2 mm Phillips #00 screws around the battery.
  4. HP Omen 15-ax243dx Hard-Drive Replacement: 手順 4、 2の画像 1 HP Omen 15-ax243dx Hard-Drive Replacement: 手順 4、 2の画像 2
    • Pull the battery cable out from its motherboard socket.
    • Pull parallel to the motherboard, not straight up.
    • Remove the battery.
    • Disconnect the power cord from the battery and transfer it to your replacement battery.
  5. HP Omen 15-ax243dx Hard-Drive Replacement, Hard-Drive: 手順 5、 1の画像 1
    • After the battery is removed, the hard drive will be easier to access in the top right hand corner.
  6. HP Omen 15-ax243dx Hard-Drive Replacement: 手順 6、 3の画像 1 HP Omen 15-ax243dx Hard-Drive Replacement: 手順 6、 3の画像 2 HP Omen 15-ax243dx Hard-Drive Replacement: 手順 6、 3の画像 3
    • With a opening tool, flip open the switch that locks in the hard drive ribbon cable into the device.
    • When lifting the cable out, lift straight up and out to prevent damage to the connector or cable.
  7. HP Omen 15-ax243dx Hard-Drive Replacement: 手順 7、 1の画像 1
    • Lift the hard drive up to remove from the device
  8. HP Omen 15-ax243dx Hard-Drive Replacement: 手順 8、 3の画像 1 HP Omen 15-ax243dx Hard-Drive Replacement: 手順 8、 3の画像 2 HP Omen 15-ax243dx Hard-Drive Replacement: 手順 8、 3の画像 3
    • Remove the rubber guards on the side of the hard drive.
    • Gently pull the plastic connector out from the hard drive.
    • The hard drive can now be disposed of if needed.
    • Save the guards and connectors from this hard drive, they will be used on the replacement part.
終わりに
3 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
vangnam
メンバー登録日: 10/19/17
594 ポイント
4のガイドは作成済み
チーム
UMass Dartmouth, Team S6-G7, Rockett Fall 2017 UMass Dartmouth, Team S6-G7, Rockett Fall 2017人のメンバー
UMASSD-ROCKETT-F17S6G7
3 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 23
過去 30 日: 72
今までの合計 8,816
