メインコンテンツにスキップ
HP Omen 15-5002xx Keyboard Replacement
必要な工具と部品
  1. HP Omen 15-5002xx Keyboard Replacement, Back Cover: 手順 1、 2の画像 1 HP Omen 15-5002xx Keyboard Replacement, Back Cover: 手順 1、 2の画像 2
    • Flip the laptop upside down so the backside is facing up.
    • Use a spudger or your fingers to remove the thin rubber strips that are attached from the edges of the laptop.
    • Remember where each thin rubber came from and set them off to the side.
    • Unscrew all 14 screw with the J00 JIS Screwdriver.
  2. HP Omen 15-5002xx Keyboard Replacement, Battery: 手順 2、 1の画像 1
    • Open the case slowly from opposite sides of the laptop.
    • Use the J00 JIS screwdriver to remove eight screws securing the battery.
  3. HP Omen 15-5002xx Keyboard Replacement: 手順 3、 2の画像 1 HP Omen 15-5002xx Keyboard Replacement: 手順 3、 2の画像 2
    • Carefully remove the battery connector that is attached to the motherboard by slowly sliding it towards the battery with two fingers.
    • Remove the battery by lifting it up and out.
  4. HP Omen 15-5002xx Keyboard Replacement, Fan: 手順 4、 1の画像 1
    この手順で使用する道具:
    Flathead 1.5 mm Screwdriver
    $5.49
    • Remove the twelve big screws with the J00 JIS screwdriver.
    • Remove all eight small screws with the 1.5 flathead screwdriver.
  5. HP Omen 15-5002xx Keyboard Replacement: 手順 5、 2の画像 1 HP Omen 15-5002xx Keyboard Replacement: 手順 5、 2の画像 2
    • Carefully detach the fan connector that is attached to the motherboard by slowly sliding the connector out with two fingers.
    • Remove the battery carefully.
  6. HP Omen 15-5002xx Keyboard Replacement, Wi-Fi Card: 手順 6、 1の画像 1
    • Use the Phillips #00 to remove one screw securing the Wi-Fi Card.
  7. HP Omen 15-5002xx Keyboard Replacement: 手順 7、 1の画像 1
    • Carefully remove the Wi-Fi Card by slowly sliding the card sideways away from the motherboard.
  8. HP Omen 15-5002xx Keyboard Replacement, Motherboard: 手順 8、 1の画像 1
    この手順で使用する道具:
    $5.49
    • Use the 1.5 flathead screwdriver and remove the twelve screws from the motherboard.
  9. HP Omen 15-5002xx Keyboard Replacement: 手順 9、 3の画像 1 HP Omen 15-5002xx Keyboard Replacement: 手順 9、 3の画像 2 HP Omen 15-5002xx Keyboard Replacement: 手順 9、 3の画像 3
    • Disconnect the four cables attached to the motherboard.
  10. HP Omen 15-5002xx Keyboard Replacement: 手順 10、 2の画像 1 HP Omen 15-5002xx Keyboard Replacement: 手順 10、 2の画像 2
    • Disconnect the remaining four connectors from the motherboard.
    • Remove the motherboard.
  11. HP Omen 15-5002xx Keyboard Replacement, Keyboard: 手順 11、 1の画像 1
    この手順で使用する道具:
    $5.49
    • Remove all 51 screws using the 1.5 mm flathead screwdriver from the underside of the keyboard.
    • All necessary screws are numbered from 1-51 on the side of each screw hole.
  12. HP Omen 15-5002xx Keyboard Replacement: 手順 12、 2の画像 1 HP Omen 15-5002xx Keyboard Replacement: 手順 12、 2の画像 2
    • Slowly pull the electricity tape off of the computer.
    • You are able to replace the electricity tape or keep the tape attached with the wire.
  13. HP Omen 15-5002xx Keyboard Replacement: 手順 13、 2の画像 1 HP Omen 15-5002xx Keyboard Replacement: 手順 13、 2の画像 2
    • With two hands, lift the keyboards from the sides.
終わりに
作成者
3人の作成者と共同で作成されました。
Hassan Isse
メンバー登録日: 09/01/21
97 ポイント
1ガイドが承認済み
チーム
Gateway, Team 1-1, Saknee Fall 2021 Gateway, Team 1-1, Saknee Fall 2021人のメンバー
GCC-SAKNEE-F21S1G1
5 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 18
過去 30 日: 55
今までの合計 1,539
