はじめに
If your printer will no longer power on and you have determined the power supply is the problem, use this guide to replace it. For this step you will need the T9 Torx screwdriver to remove the two 9.6 mm screws in the replacement.
必要な工具と部品
Remove the two 11.6 mm T9 screws from the right side of the back of the printer.
Remove the the black cable from the bottom of the motherboard by carefully pulling down on the connection.
2 の人々がこのガイドを完成させました。
