はじめに
The CMOS battery is an on-board memory storage battery. If you're HP Officejet Pro 8625 is losing data frequently or shutting off randomly, you may need to replace the CMOS battery. Removing the CMOS battery will reset all settings to default.
必要な工具と部品
Remove the two 11.6 mm T9 screws from the right side of the back of the printer.
Remove the three 5.3 mm T9 screws from the motherboard.
Remove the one 6.7 mm T9 screw from the motherboard.
Locate the CMOS battery on the motherboard.
Remove the CMOS battery by pinching the top and pulling away from the motherboard.
終わりに
