メインコンテンツにスキップ
HP Officejet Pro 8600 Plus Motherboard Replacement
必要な工具と部品
  1. HP Officejet Pro 8600 Plus Motherboard Replacement, Motherboard: 手順 1、 2の画像 1 HP Officejet Pro 8600 Plus Motherboard Replacement, Motherboard: 手順 1、 2の画像 2
    • Turn the printer so the back is facing you.
    • Put the printer in a vertical position by lifting its right side.
  2. HP Officejet Pro 8600 Plus Motherboard Replacement: 手順 2、 1の画像 1
    • Remove the two 12mm T10 Torx screws on the top edge of the printer.
  3. HP Officejet Pro 8600 Plus Motherboard Replacement: 手順 3、 1の画像 1
    • Rotate the printer clockwise so the bottom of the printer is facing you.
  4. HP Officejet Pro 8600 Plus Motherboard Replacement: 手順 4、 2の画像 1 HP Officejet Pro 8600 Plus Motherboard Replacement: 手順 4、 2の画像 2
    • Insert the plastic opening tool underneath the slot on the right that aligns with the edge of the back panel.
    • Insert a second plastic opening tool in the notch lining up with the crease in the back panel.
    • This step requires applying a significant amount of force on the left notch. Don't be alarmed if you hear popping noises.
  5. HP Officejet Pro 8600 Plus Motherboard Replacement: 手順 5、 1の画像 1
    • Remove the side panel from the printer by lifting upwards toward you.
    • For reassembly, slide the side panel from left to right into place.
  6. HP Officejet Pro 8600 Plus Motherboard Replacement: 手順 6、 1の画像 1
    • Remove the four 6.5 mm T10 Torx screws from the motherboard.
  7. HP Officejet Pro 8600 Plus Motherboard Replacement: 手順 7、 1の画像 1
    • Remove the black brace from the right side of the motherboard, located near the black ribbon cable.
  8. HP Officejet Pro 8600 Plus Motherboard Replacement: 手順 8、 3の画像 1 HP Officejet Pro 8600 Plus Motherboard Replacement: 手順 8、 3の画像 2 HP Officejet Pro 8600 Plus Motherboard Replacement: 手順 8、 3の画像 3
    • Remove the cables connected to the top of the motherboard by gently pulling them out of their ports.
    • Remove the cables connected to the edge of the motherboard by gently pulling them out of their ports.
    • Remove the cables connected to the underside of the motherboard by gently pulling them out of their ports.
終わりに
6 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Mackinnon Buck
メンバー登録日: 04/18/18
1,248 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team S16-G4, Livingston Spring 2018 Cal Poly, Team S16-G4, Livingston Spring 2018人のメンバー
CPSU-LIVINGSTON-S18S16G4
4 メンバー
11のガイドは作成済み
2 件のコメント
Hi,
Was having trouble with wifi connectivity. Printer says it is connected but can’t get to on the network. Shows IP address and all looks good from printer side but can’t find printer on network even with the assigned IP address. I replaced the mother board as shown above but still the same problem. Any ideas on what the problem may be? Every other device on network works fine but this HP printer. Phones, Chrome books, laptops, i-Pads… Any help would be appreciated.
Last note - There was a small circuit board attached to the mother board. I removed from the old MB and put on new MB. Could this be wireless card and if so any source for a new one. Only place I could find MB was on NewEgg.
THANKS!!
Oh, and BTW - instruction for MB removal were excellent!!
Don - 返信
Are there any procedures required after either battery replacement or motherboard replacement? Re-loading of firmware, initialization, etc. Does the printer's serial number change as a result of battery replacement or motherboard replacement?
Erik Fjerstad - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 23
過去 30 日: 71
今までの合計 5,167
