メインコンテンツにスキップ
HP Officejet Pro 8600 Plus Battery Replacement
必要な工具と部品
  1. HP Officejet Pro 8600 Plus Battery Replacement, Motherboard: 手順 1、 2の画像 1 HP Officejet Pro 8600 Plus Battery Replacement, Motherboard: 手順 1、 2の画像 2
    • Turn the printer so the back is facing you.
    • Put the printer in a vertical position by lifting its right side.
  2. HP Officejet Pro 8600 Plus Battery Replacement: 手順 2、 1の画像 1
    • Remove the two 12mm T10 Torx screws on the top edge of the printer.
  3. HP Officejet Pro 8600 Plus Battery Replacement: 手順 3、 1の画像 1
    • Rotate the printer clockwise so the bottom of the printer is facing you.
  4. HP Officejet Pro 8600 Plus Battery Replacement: 手順 4、 2の画像 1 HP Officejet Pro 8600 Plus Battery Replacement: 手順 4、 2の画像 2
    • Insert the plastic opening tool underneath the slot on the right that aligns with the edge of the back panel.
    • Insert a second plastic opening tool in the notch lining up with the crease in the back panel.
    • This step requires applying a significant amount of force on the left notch. Don't be alarmed if you hear popping noises.
  5. HP Officejet Pro 8600 Plus Battery Replacement: 手順 5、 1の画像 1
    • Remove the side panel from the printer by lifting upwards toward you.
    • For reassembly, slide the side panel from left to right into place.
  6. HP Officejet Pro 8600 Plus Battery Replacement: 手順 6、 1の画像 1
    • Remove the four 6.5 mm T10 Torx screws from the motherboard.
  7. HP Officejet Pro 8600 Plus Battery Replacement: 手順 7、 1の画像 1
    • Remove the black brace from the right side of the motherboard, located near the black ribbon cable.
  8. HP Officejet Pro 8600 Plus Battery Replacement: 手順 8、 3の画像 1 HP Officejet Pro 8600 Plus Battery Replacement: 手順 8、 3の画像 2 HP Officejet Pro 8600 Plus Battery Replacement: 手順 8、 3の画像 3
    • Remove the cables connected to the top of the motherboard by gently pulling them out of their ports.
    • Remove the cables connected to the edge of the motherboard by gently pulling them out of their ports.
    • Remove the cables connected to the underside of the motherboard by gently pulling them out of their ports.
  9. HP Officejet Pro 8600 Plus Battery Replacement, Battery: 手順 9、 2の画像 1 HP Officejet Pro 8600 Plus Battery Replacement, Battery: 手順 9、 2の画像 2
    • Turn the motherboard over so the back is facing upward.
    • Use the plastic opening tool to pry the battery out of place.
  10. HP Officejet Pro 8600 Plus Battery Replacement: 手順 10、 1の画像 1
    • Remove the battery by grabbing its edges, lifting upward, and sliding sideways.
終わりに
9 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Mackinnon Buck
メンバー登録日: 04/18/18
1,182 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team S16-G4, Livingston Spring 2018 Cal Poly, Team S16-G4, Livingston Spring 2018人のメンバー
CPSU-LIVINGSTON-S18S16G4
4 メンバー
10のガイドは作成済み
2 件のコメント
Are there any procedures required after either battery replacement or motherboard replacement? Re-loading of firmware, initialization, etc. Does the printer's serial number change as a result of battery replacement or motherboard replacement?
Erik Fjerstad - 返信
Bonjour ,
ma batterie est ok , par contre la courroie s'effiloche.
Peut on la remplacer et si oui comment y accéder?
J'ai déplacé le tendeur pour augmenter la tension de la courroie mais ce n'est pas suffisant.
Merci
BàV phil
Philippe Herbots - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 14
過去 30 日: 99
今までの合計 5,089
