はじめに
The sensor chip is a small, green chip located in the top-right corner inside printer. It is held in by a small screw.
必要な工具と部品
Open the main lid as far as it will go.
Use a plastic opening tool to gently pry off the hinge on the right side by pushing it to the left and off the hook.
Open the lid further.
Twist the screwdriver counter-clockwise to remove the T9 screw on the sensor chip.
ある他の人がこのガイドを完成しました。
