メインコンテンツにスキップ
HP Notebook 15-ay011nr Hard Drive Replacement
必要な工具と部品
    • Before disassembling the computer, follow these steps:
    • Shut down the computer
    • If you are unsure whether the computer is in hibernation, turn the computer on, and then shut it down through the operating system.
    • Disconnect all external devices connected to the computer
    • Disconnect the power from the computer by first unplugging the power cord from the AC outlet and then unplugging the AC adapter from the computer
  1. HP Notebook 15-ay011nr Hard Drive Replacement, Removing the battery: 手順 2、 1の画像 1
    • To remove the battery:
    • Position the computer upside down on a flat surface
    • Slide the battery lock latch (1)
    • Slide the battery release latch (2)
    • Remove the battery (3) from the computer
  2. HP Notebook 15-ay011nr Hard Drive Replacement, Optical Drive: 手順 3、 1の画像 1
    • To remove the optical drive:
    • Remove the Philips PM2.5x6.0 screw (1)
    • Remove the optical drive (2) by sliding it out of the optical drive bay
  3. HP Notebook 15-ay011nr Hard Drive Replacement, Bottom Cover: 手順 4、 1の画像 1
    • To remove the bottom cover:
    • Position the computer upside down the the front toward you
    • Remove the two rubber feet from the rear of the bottom of the computer (1)
    • Remove the 11 Philips PM2.5x6 screws (2) from the bottom of the computer
    • Remove the 2 Philips PM2x2 screws (3) from the optical drive bay
  4. HP Notebook 15-ay011nr Hard Drive Replacement, Solid-state drive: 手順 5、 1の画像 1
    • Remove the solid-state drive
    • Remove the Philips PM2x2 screw (1) that secures the drive to the system board
    • Remove the drive (2) by pulling it away from the connector
終わりに
作成者
2人の作成者と共同で作成されました。
Alec Ringberg
メンバー登録日: 08/05/18
625 ポイント
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 5
今までの合計 826
