メインコンテンツにスキップ
HP Mini 210-2070NR Keyboard Replacement
必要な工具と部品
  1. HP Mini 210-2070NR Keyboard Replacement, Battery and Service Access Cover: 手順 1、 1の画像 1
    • Before beginning, make sure that your computer is turned off and all external power cords are disconnected.
    • Close the laptop and turn it over so that the underside is up and the silver battery bay is facing towards you.
  2. HP Mini 210-2070NR Keyboard Replacement: 手順 2、 3の画像 1 HP Mini 210-2070NR Keyboard Replacement: 手順 2、 3の画像 2 HP Mini 210-2070NR Keyboard Replacement: 手順 2、 3の画像 3
    • The battery locking latch is on the bottom right corner; slide it inward to unlock the battery.
    • Slide the battery release latch inwards.
    • Pull the battery towards you to remove it.
  3. HP Mini 210-2070NR Keyboard Replacement: 手順 3、 3の画像 1 HP Mini 210-2070NR Keyboard Replacement: 手順 3、 3の画像 2 HP Mini 210-2070NR Keyboard Replacement: 手順 3、 3の画像 3
    • Slide the service access cover release lever to the right.
    • While holding the lever to the right, lift up the laptop's bottom cover gently and remove the cover.
  4. HP Mini 210-2070NR Keyboard Replacement: 手順 4、 1の画像 1
    • Orient the computer as shown in the picture.
  5. HP Mini 210-2070NR Keyboard Replacement, Keyboard: 手順 5、 2の画像 1 HP Mini 210-2070NR Keyboard Replacement, Keyboard: 手順 5、 2の画像 2
    • Using a 00 Phillips screwdriver, unscrew and remove the three 2.0 X 5.0 screws that connect the keyboard to the computer.
    • Each of the screws are labeled with small keyboards next to them.
    • Flip the computer over so that the front is facing you.
  6. HP Mini 210-2070NR Keyboard Replacement: 手順 6、 3の画像 1 HP Mini 210-2070NR Keyboard Replacement: 手順 6、 3の画像 2 HP Mini 210-2070NR Keyboard Replacement: 手順 6、 3の画像 3
    • Open the computer screen as far as possible. It should be able to lay flat on whatever surface you are working on.
    • Pry along the rear edge of the keyboard away from the PC with the plastic opening tool.
    • Once enough of an opening has been established, gently grasp the edge and pull the keyboard towards you.
    • There is a cable connecting the keyboard to the laptop, so do not attempt to fully remove the keyboard yet or you will damage your device.
  7. HP Mini 210-2070NR Keyboard Replacement: 手順 7、 2の画像 1 HP Mini 210-2070NR Keyboard Replacement: 手順 7、 2の画像 2
    • Use your fingernail to flip up the black retaining flap attached to the keyboard ZIF connector.
    • Pull the keyboard cable out of its socket to disconnect it.
  8. HP Mini 210-2070NR Keyboard Replacement: 手順 8、 1の画像 1
    • Remove the keyboard by lifting it away from the computer.
終わりに
作成者
6人の作成者と共同で作成されました。
Sean Kuster
メンバー登録日: 10/05/12
91 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 3-23, Amido Fall 2012 Cal Poly, Team 3-23, Amido Fall 2012人のメンバー
CPSU-AMIDO-F12S3G23
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 12
今までの合計 1,626
