メインコンテンツにスキップ
HP Mini 210-2070NR Hard Drive Replacement
必要な工具と部品
  1. HP Mini 210-2070NR Hard Drive Replacement, Battery and Service Access Cover: 手順 1、 1の画像 1
    • Before beginning, make sure that your computer is turned off and all external power cords are disconnected.
    • Close the laptop and turn it over so that the underside is up and the silver battery bay is facing towards you.
  2. HP Mini 210-2070NR Hard Drive Replacement: 手順 2、 3の画像 1 HP Mini 210-2070NR Hard Drive Replacement: 手順 2、 3の画像 2 HP Mini 210-2070NR Hard Drive Replacement: 手順 2、 3の画像 3
    • The battery locking latch is on the bottom right corner; slide it inward to unlock the battery.
    • Slide the battery release latch inwards.
    • Pull the battery towards you to remove it.
  3. HP Mini 210-2070NR Hard Drive Replacement: 手順 3、 3の画像 1 HP Mini 210-2070NR Hard Drive Replacement: 手順 3、 3の画像 2 HP Mini 210-2070NR Hard Drive Replacement: 手順 3、 3の画像 3
    • Slide the service access cover release lever to the right.
    • While holding the lever to the right, lift up the laptop's bottom cover gently and remove the cover.
  4. HP Mini 210-2070NR Hard Drive Replacement: 手順 4、 1の画像 1
    • Orient the computer as shown in the picture.
  5. HP Mini 210-2070NR Hard Drive Replacement, Hard Drive: 手順 5、 3の画像 1 HP Mini 210-2070NR Hard Drive Replacement, Hard Drive: 手順 5、 3の画像 2 HP Mini 210-2070NR Hard Drive Replacement, Hard Drive: 手順 5、 3の画像 3
    • Remove the HP product sticker.
    • Be careful not to pull up the black hard drive plastic connector with the sticker. Also, removing this sticker will void your warranty.
  6. HP Mini 210-2070NR Hard Drive Replacement: 手順 6、 2の画像 1 HP Mini 210-2070NR Hard Drive Replacement: 手順 6、 2の画像 2
    • Locate the hard drive, where the HP Product sticker used to be.
    • Locate the hard drive cable, connected to the hard drive.
    • Disconnect the hard drive cable by gently pulling upward.
  7. HP Mini 210-2070NR Hard Drive Replacement: 手順 7、 2の画像 1 HP Mini 210-2070NR Hard Drive Replacement: 手順 7、 2の画像 2
    • Using a #00 Phillips screwdriver, unscrew and remove the three 2.0 x 4.0 Philips screws holding the hard drive in place.
  8. HP Mini 210-2070NR Hard Drive Replacement: 手順 8、 2の画像 1 HP Mini 210-2070NR Hard Drive Replacement: 手順 8、 2の画像 2
    • Use the Mylar Tab located on the right side of the hard drive to pry up the hard drive.
    • Remove the hard drive.
  9. HP Mini 210-2070NR Hard Drive Replacement: 手順 9、 1の画像 1
    • Lay the hard drive down with the underside facing up.
    • Pull and remove the hard drive pin connector from the hard drive.
終わりに
4 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Alek Linquist
メンバー登録日: 10/05/12
123 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 3-23, Amido Fall 2012 Cal Poly, Team 3-23, Amido Fall 2012人のメンバー
CPSU-AMIDO-F12S3G23
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 7
今までの合計 2,258
