メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HP Mini 210 Keyboard Replacement
必要な工具と部品
  1. HP Mini 210 Keyboard Replacement, Battery: 手順 1、 2の画像 1 HP Mini 210 Keyboard Replacement, Battery: 手順 1、 2の画像 2
    • Turn off and unplug the netbook before replacing the battery.
    • Hold the netbook top-side down with the lid closed.
    • Slide the plastic battery release latches towards the lock symbols.
    • The left tab unlocks completely, but you will need to hold the right tab towards the lock symbol as you remove the battery.
    FixBotに聞いてみる
  2. HP Mini 210 Keyboard Replacement: 手順 2、 1の画像 1
    • Slide the battery out from the netbook.
    FixBotに聞いてみる
  3. HP Mini 210 Keyboard Replacement, Disassembling HP Mini 210 Back Case: 手順 3、 1の画像 1
    • Turn the netbook to view its edge.
    • Press both orange eject buttons simultaneously, and use a spudger to pry off the back case.
    FixBotに聞いてみる
  4. HP Mini 210 Keyboard Replacement: 手順 4、 1の画像 1
    • If the back case does not separate from the netbook easily, use the spudger to pry off the back case by the edge near the battery compartment, and work your way to the sides. The case will then pivot along the front edge.
    FixBotに聞いてみる
  5. HP Mini 210 Keyboard Replacement: 手順 5、 1の画像 1
    • Pull the back case off from the front edge.
    FixBotに聞いてみる
  6. HP Mini 210 Keyboard Replacement, Keyboard: 手順 6、 3の画像 1 HP Mini 210 Keyboard Replacement, Keyboard: 手順 6、 3の画像 2 HP Mini 210 Keyboard Replacement, Keyboard: 手順 6、 3の画像 3
    • Using a screwdriver, remove the three 6.6 mm screws highlighted with the red circles in the first picture above.
    FixBotに聞いてみる
  7. HP Mini 210 Keyboard Replacement: 手順 7、 2の画像 1 HP Mini 210 Keyboard Replacement: 手順 7、 2の画像 2
    • Once you have removed the screws, flip the netbook over so that the keyboard is now facing upwards. Open the screen as far back as the netbook allows.
    • Using a prying tool, lift upwards and remove the plastic casing that covers the spaces around the keys of the keyboard.
    • Be careful when removing the plastic casing.
    FixBotに聞いてみる
  8. HP Mini 210 Keyboard Replacement: 手順 8、 3の画像 1 HP Mini 210 Keyboard Replacement: 手順 8、 3の画像 2 HP Mini 210 Keyboard Replacement: 手順 8、 3の画像 3
    • After removing the plastic casing surrounding the keys, carefully lift the full keyboard from the netbook using a plastic opening tool.
    • Do not yank the keyboard out. The keyboard is attached to the netbook through a ribbon cable, which needs to remain undamaged in order for the new keyboard to properly connect with the netbook.
    FixBotに聞いてみる
  9. HP Mini 210 Keyboard Replacement: 手順 9、 3の画像 1 HP Mini 210 Keyboard Replacement: 手順 9、 3の画像 2 HP Mini 210 Keyboard Replacement: 手順 9、 3の画像 3
    • Be very gentle with the ZIF connector! It is designed to be locked into the motherboard, so make sure you lift the retaining latch before attempting to disconnect it.
    • Lift the latch on the ZIF (zero insertion-force) connector using a plastic opening tool. The ZIF connector is located on the motherboard and is connected to the keyboard through the ribbon cable.
    • Disconnect the ribbon cable from the ZIF connector on the motherboard by lifting it up and out; this completely removes the keyboard.
    FixBotに聞いてみる
終わりに
11 の人々がこのガイドを完成させました。
作成者
9人の作成者と共同で作成されました。
Heather Freed
メンバー登録日: 10/06/12
723 ポイント
8のガイドは作成済み
チーム
Cal Poly, Team 9-17, Amido Fall 2012 Cal Poly, Team 9-17, Amido Fall 2012人のメンバー
CPSU-AMIDO-F12S9G17
3 メンバー
8のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 16
過去 30 日: 90
今までの合計 15,616
