メインコンテンツにスキップ
HP Mini 210 CMOS Battery Replacement
必要な工具と部品
  1. HP Mini 210 CMOS Battery Replacement, Battery: 手順 1、 2の画像 1 HP Mini 210 CMOS Battery Replacement, Battery: 手順 1、 2の画像 2
    • Turn off and unplug the netbook before replacing the battery.
    • Hold the netbook top-side down with the lid closed.
    • Slide the plastic battery release latches towards the lock symbols.
    • The left tab unlocks completely, but you will need to hold the right tab towards the lock symbol as you remove the battery.
  2. HP Mini 210 CMOS Battery Replacement: 手順 2、 1の画像 1
    • Slide the battery out from the netbook.
  3. HP Mini 210 CMOS Battery Replacement, Disassembling HP Mini 210 Back Case: 手順 3、 1の画像 1
    • Turn the netbook to view its edge.
    • Press both orange eject buttons simultaneously, and use a spudger to pry off the back case.
  4. HP Mini 210 CMOS Battery Replacement: 手順 4、 1の画像 1
    • If the back case does not separate from the netbook easily, use the spudger to pry off the back case by the edge near the battery compartment, and work your way to the sides. The case will then pivot along the front edge.
  5. HP Mini 210 CMOS Battery Replacement: 手順 5、 1の画像 1
    • Pull the back case off from the front edge.
  6. HP Mini 210 CMOS Battery Replacement, CMOS Battery: 手順 6、 1の画像 1
    • Cut one side of the black adhesive ribbon on top of the CMOS battery with a utility blade.
    • Be careful not to scratch or damage the battery or netbook, and be sure to keep your fingers out of the way!
  7. HP Mini 210 CMOS Battery Replacement: 手順 7、 1の画像 1
    • Slowly peel back the black adhesive ribbon with tweezers.
  8. HP Mini 210 CMOS Battery Replacement: 手順 8、 1の画像 1
    • Pry the CMOS battery out with a plastic opening tool.
  9. HP Mini 210 CMOS Battery Replacement: 手順 9、 1の画像 1
    • Pop the CMOS battery out.
    • When reinstalling, insert the battery back into the slot with the positive terminal facing up.
終わりに
8 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Heather Freed
メンバー登録日: 10/06/12
723 ポイント
8のガイドは作成済み
チーム
Cal Poly, Team 9-17, Amido Fall 2012 Cal Poly, Team 9-17, Amido Fall 2012人のメンバー
CPSU-AMIDO-F12S9G17
3 メンバー
8のガイドは作成済み
コメント 1 件
after need CMOS reset. Screen is black. Is there an easy way on my HP Mini 210?
Carl Louviere - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 11
過去 30 日: 35
今までの合計 15,372
