必要な工具と部品
Power off the laptop before trying to remove the battery.
Turn the laptop upside down, and locate the sliding tabs on the battery.
Slide both tabs in an inward direction, then slide the battery away from the laptop.
To remove the bottom cover pull the orange tab to the right until it clicks.
Carefully disconnect the clips as you lift the bottom cover.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
