メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HP Mini 110-1046NR Fan Replacement
必要な工具と部品
  1. HP Mini 110-1046NR Fan Replacement, Battery: 手順 1、 3の画像 1 HP Mini 110-1046NR Fan Replacement, Battery: 手順 1、 3の画像 2 HP Mini 110-1046NR Fan Replacement, Battery: 手順 1、 3の画像 3
    • Power-off the netbook fully before attempting to remove the battery.
    • Flip your netbook upside down, and locate the sliding tabs near the battery.
    • Slide both tabs inward so that the battery visibly moves away from the case of the computer.
    • Release the tabs and pull the battery out.
    FixBotに聞いてみる
    コメントを追加
  2. HP Mini 110-1046NR Fan Replacement, Keyboard: 手順 2、 2の画像 1 HP Mini 110-1046NR Fan Replacement, Keyboard: 手順 2、 2の画像 2
    • With the screen closed, turn your netbook around so that the battery slot is facing you.
    • Remove the three 2.9mm screws in the battery slot.
    • This step can be made easier by using a magnetic screwdriver.
    FixBotに聞いてみる
    コメントを追加
  3. HP Mini 110-1046NR Fan Replacement: 手順 3、 3の画像 1 HP Mini 110-1046NR Fan Replacement: 手順 3、 3の画像 2 HP Mini 110-1046NR Fan Replacement: 手順 3、 3の画像 3
    • Flip the netbook upright, and open the screen as far as it will go.
    • Pry up the keyboard from the middle of the top edge.
    • Insert the flat end of the spudger between middle of the the top edge of the keyboard and the plastic frame behind it.
    • Pry the keyboard up until it pops out or until you can grab it with your fingers, and then pull gently until it pops out on both sides.
    • Do not pull the keyboard out immediately - there is a potentially fragile ribbon cable that attaches to the motherboard behind the keyboard.
    FixBotに聞いてみる
    コメントを追加
  4. HP Mini 110-1046NR Fan Replacement: 手順 4、 3の画像 1 HP Mini 110-1046NR Fan Replacement: 手順 4、 3の画像 2 HP Mini 110-1046NR Fan Replacement: 手順 4、 3の画像 3
    • Flip the keyboard over (toward you) by pivoting it about the lower edge, and lay it upside down on top of the touchpad area to reveal the ribbon cable.
    • Lightly pull up on the black tab on top of the keyboard ribbon cable until it hinges toward you and releases the ribbon cable end.
    • Pull the ribbon cable backward and out of the receptacle. This should not require any effort.
    FixBotに聞いてみる
    コメントを追加
  5. HP Mini 110-1046NR Fan Replacement, Hard Drive: 手順 5、 3の画像 1 HP Mini 110-1046NR Fan Replacement, Hard Drive: 手順 5、 3の画像 2 HP Mini 110-1046NR Fan Replacement, Hard Drive: 手順 5、 3の画像 3
    • Remove the three screws holding down the hard drive. Use a Phillips PH0 screwdriver for the two silver, 3.4mm screws on the right, and use a PH1 for the black, 10.3mm screw on the left.
    • It is not necessary to fully remove the 10.3mm screw, but if you do, be careful to not lose the spring.
    FixBotに聞いてみる
    コメントを追加
  6. HP Mini 110-1046NR Fan Replacement: 手順 6、 3の画像 1 HP Mini 110-1046NR Fan Replacement: 手順 6、 3の画像 2 HP Mini 110-1046NR Fan Replacement: 手順 6、 3の画像 3
    • As shown on the top face of the hard drive itself, pull hard drive left using the black tab until the hard drive is unplugged and entirely released from its receptacle.
    • Lift the hard drive out of the laptop.
    • Place the hard drive in an anti-static bag to reduce the likelihood of damaging it with static electricity.
    FixBotに聞いてみる
    コメントを追加
  7. HP Mini 110-1046NR Fan Replacement, Memory Card Cover: 手順 7、 3の画像 1 HP Mini 110-1046NR Fan Replacement, Memory Card Cover: 手順 7、 3の画像 2 HP Mini 110-1046NR Fan Replacement, Memory Card Cover: 手順 7、 3の画像 3
    • Flip the netbook over so you are looking at the bottom, and locate the two screws that hold the memory card cover.
    • Next, take a Phillips PH1 screwdriver and unscrew the two screws.
    • These screws will not release from the cover once they are unscrewed.
    • If necessary, use the flat end of the spudger to assist in prying the cover away from the computer.
    FixBotに聞いてみる
    コメントを追加
  8. HP Mini 110-1046NR Fan Replacement, Keyboard Bezel: 手順 8、 2の画像 1 HP Mini 110-1046NR Fan Replacement, Keyboard Bezel: 手順 8、 2の画像 2
    • It is not necessary to remove the memory card for this step.
    • Remove the 4.9mm screw located to the right of the of the memory card using a PH1 screwdriver.
    FixBotに聞いてみる
    コメントを追加
  9. HP Mini 110-1046NR Fan Replacement: 手順 9、 3の画像 1 HP Mini 110-1046NR Fan Replacement: 手順 9、 3の画像 2 HP Mini 110-1046NR Fan Replacement: 手順 9、 3の画像 3
    • Pry the four feet with the pick-end of the spudger. These are glued down, so this may require some force.
    • Remove the 6mm PH1 screws located under each foot.
    FixBotに聞いてみる
    コメントを追加
  10. HP Mini 110-1046NR Fan Replacement: 手順 10、 3の画像 1 HP Mini 110-1046NR Fan Replacement: 手順 10、 3の画像 2 HP Mini 110-1046NR Fan Replacement: 手順 10、 3の画像 3
    • Flip the netbook over and remove with a PH1 screwdriver the eight 5.9mm screws that secure the keyboard bezel in place.
    • Only remove the black screws with "M2.5x6" markings next to them. All others are unnecessary.
    • Taking the keyboard bezel off without removing the hard drive may be possible, but there is a risk of breaking several tabs on the keyboard bezel located between the hard drive and the frame of the computer.
    • Using the flat end of the spudger or pry stick, pry the keyboard bezel away from the base by wedging the tool between the base and keyboard bezel and run the tool along the side until the cover is fully released.
    • Don't pull the front of the keyboard up very far. There is a small, potentially fragile ribbon cable on the back of the touchpad that is still attached to the system board.
    • Carefully flip the keyboard bezel over (toward you) to reveal the touchpad ribbon cable.
    FixBotに聞いてみる
    コメントを追加
  11. HP Mini 110-1046NR Fan Replacement: 手順 11、 3の画像 1 HP Mini 110-1046NR Fan Replacement: 手順 11、 3の画像 2 HP Mini 110-1046NR Fan Replacement: 手順 11、 3の画像 3
    • Locate the black and white tab that connects the touchpad ribbon cable to the motherboard.
    • Using your fingernail or a pry stick, flip the white tab up to release the ribbon cable end.
    • Remove the touchpad ribbon cable from the receptacle on the system board by gently pulling the ribbon away from the clamp.
    FixBotに聞いてみる
    コメントを追加
  12. HP Mini 110-1046NR Fan Replacement, Fan: 手順 12、 2の画像 1 HP Mini 110-1046NR Fan Replacement, Fan: 手順 12、 2の画像 2
    • Locate the two 3.8mm screws that hold the fan to the frame of the computer.
    • You may have to hold wires out of the way to access one of the screws.
    • Remove the screws with a Phillips PH1 screwdriver.
    FixBotに聞いてみる
    コメントを追加
  13. HP Mini 110-1046NR Fan Replacement: 手順 13、 2の画像 1 HP Mini 110-1046NR Fan Replacement: 手順 13、 2の画像 2
    • Unplug the fan power cable by pushing the connector away from the receptacle with a pry stick and one finger (or two pry sticks).
    • Lift the fan out of the computer.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
4 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Amos Hine
メンバー登録日: 10/18/13
1,275 ポイント
7のガイドは作成済み
チーム
Clemson, Team 14-1, Benson Fall 2013 Clemson, Team 14-1, Benson Fall 2013人のメンバー
CLEM-BENSON-F13S14G1
3 メンバー
12のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 41
今までの合計 4,468
