はじめに
Replace the USB and Power board in your HP Mini 1000.
パーツ
パーツは必要ありません。
  1. With the case closed, place the Mini 1000 top-side down on a flat surface.
    • With the case closed, place the Mini 1000 top-side down on a flat surface.
    • Push both of the battery release latches toward each other.
  2. Lift the battery out of the Mini 1000 from the edge closest to the release latches.
    • Lift the battery out of the Mini 1000 from the edge closest to the release latches.
    • Remove the following two screws:
      • One 6 mm Phillips screw
      • One 4 mm Phillips screw
    • To facilitate the removal of the keyboard, it is recommended to push the keyboard outwards with one hand through the opening (highlighted in the third picture) located on the backside of the Mini 1000.
    • While pushing through the opening with one hand, grasp the left upper edge with the other hand and slightly pull the keyboard towards you.
    • Once an opening has been established, grasp the keyboard and slowly lift it upwards along the upper perimeter of the top edge.
    • Lift the keyboard out of the upper case, minding the cable that is still connecting it to the motherboard.
    • Use your fingernail or the flat end of a spudger to flip up the retaining flap on the keyboard cable ZIF socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the cable out of its socket and remove the keyboard.
    • Use your fingernail or the flat end of a spudger to flip up the retaining flap on the SIM card ribbon cable ZIF socket.
    • Pull the SIM card ribbon cable out of its socket and peel it off the top of the hard drive enclosure.
    • Use your fingernail or the flat end of a spudger to flip up the retaining flap on the hard drive cable ZIF socket.
    • Remove the two 4.5 mm Phillips screws securing the hard drive to the lower case.
    • Lift the hard drive up and out of the lower case, being careful not to damage its cable in the process.
    • Using the sharp tip of a spudger, pry and remove the four plastic screw covers from the underside of the HP Mini 1000.
    • There are three different variations of the covers:
      • The two bottom covers are short in height and are notched to prevent incorrect insertion
      • The upper right cover is taller in height and is notched.
      • The upper left cover is taller in height and is not notched.
    • Remove the four 7 mm Phillips screws that secure the upper case to the lower case.
    • Flip the computer over and open the display.
    • Remove the two 4.5 mm Phillips screws securing the upper case to the lower case.
    • Wedge the flat end of a spudger in between the upper case and lower case near the bottom right corner of the display.
    • Carefully pry and rock the spudger upwards to create a small gap between the upper case and lower case.
    • Continue the previously described motion along the right edge of the upper case to release the clips securing the upper case to the lower case.
    • Repeat the same procedure as mentioned in the previous step to release the clips along the left side of the upper case.
    • Grasp the upper case and carefully lift it slightly upwards, freeing it from any remaining clips.
    • The upper case is still attached via the TouchPad ribbon cable that is connected to the motherboard. Do not remove it completely just yet.
    • Lay the upper case on top of the upper portion of the motherboard.
    • Use your fingernail or the flat end of a spudger to flip up the retaining flap on the TouchPad cable ZIF socket.
    • Pull the TouchPad ribbon cable out of its socket.
    • Remove the upper case from the HP Mini 1000.
    • Push the SD card toward the inside of the computer to unlock it from the lower case.
    • Pull the SD card out of the lower case.
    • If present, peel the sticker up off the top of the Wi-Fi board to reveal the Wi-Fi antenna connectors.
    • Pry the Wi-Fi antenna connectors (2 total) up off the Wi-Fi board.
    • During reassembly, remember to correctly connect the antenna cables to their respective terminals. The green labeled antenna is connected to the "MAIN" terminal and the white labeled antenna is connected to the "AUX" terminal.
    • Remove the single 3 mm Phillips screw securing Wi-Fi board to the motherboard.
    • Upon removing the Phillips screw that secures the Wi-Fi board to the motherboard, the Wi-Fi board should pop up from its top side nearest the antenna sockets.
    • Grasp the Wi-Fi board and lift it straight away from its socket on the motherboard.
    • Remove the two 2.5 mm Phillips screws securing the heat sink to the motherboard.
    • Carefully lift the heat sink off the face of the motherboard and de-route the curved section from next to the fan.
    • Before reinstalling the heat sink, be sure to apply a new layer of thermal paste to the CPU. We have a thermal paste guide that makes it easy.
    • Only apply a new layer of thermal paste to the face of the CPU. The CPU is the large processor located closest to the fan.
    • If present, carefully peel the piece of tape covering the WWAN board.
    • Pry the WWAN antenna connectors (2 total) up off the WWAN board.
    • During reassembly, remember to correctly connect the antenna cables to their respective terminals. The red labeled antenna is connected to the "MAIN" terminal and the blue labeled antenna is connected to the "AUX" terminal.
    • Remove the single 3 mm Phillips screw securing the WWAN metal bracket and WWAN board to the motherboard.
    • During reassembly, before securing the WWAN board to the upper case, be sure the metal bracket is correctly placed (as highlighted in the second picture).
    • Be cautious of the metal bracket's displacement. It can easily become lost during disassembly.
    • Upon removing the Phillips screw that secures the WWAN board to the motherboard, the WWAN board should pop up from its left side.
    • Grasp the WWAN board and pull it straight out of its socket on the motherboard.
    • Use the flat end of a spudger to lift the Bluetooth cable connector out of its socket on the motherboard.
    • Carefully pry the Bluetooth board off the motherboard and remove it from the Mini 1000.
    • If present, carefully peel back the piece of black film attached to the heat sink to reveal the PRAM battery and its cable.
    • Use a pair of tweezers to pull the PRAM battery connector out of its socket on the motherboard.
    • Pull the connector parallel to the face of the motherboard toward the fan side of the computer.
    • Use the flat end of a spudger to pry the PRAM battery off the adhesive securing it to the motherboard.
    • Remove the PRAM battery.
    • If present, remove the large piece of black adhesive film covering the area around the fan.
    • If present, remove the pieces of black cloth tape securing the antenna cables to the motherboard.
    • Use the flat end of a spudger or your fingers to disconnect the following cables:
      • Speaker cable
      • Microphone cable
      • Fan cable
      • Power cable
      • Display data cable
    • Do not lift the connectors up as you disconnect them from the motherboard. Push the connectors out of their sockets parallel to the face of the logic board toward the display assembly. Use extra care when disconnecting the display data cable, as its connector and socket are fragile.
    • Remove the 2.5 mm Phillips screw securing the power switch lever to the lower case.
    • Use a pair of tweezers or your fingers to lift the power switch lever out of the Mini 1000.
    • Remove the 2.5 mm Phillips screw securing the wireless on/off switch lever to the lower case.
    • Use tweezers or your fingers to remove the wireless on/off switch lever from the Mini 1000.
    • Remove the two 3 mm Phillips screws securing the USB bracket to the lower case.
    • Pry up the USB bracket and remove it from the motherboard.
    • Remove the single 4.5 mm Phillips screw securing the motherboard to the lower case near the fan.
    • Carefully lift the motherboard from its right edge and remove it from the lower case, minding any cables that may get caught.
    • If present, remove the piece of black cloth tape holding the bundle of cables to the top of the fan.
    • Carefully untangle the fan cable from the bundle of cables leading to the display.
      • One 3 mm Phillips screw
      • One 4.5 mm Phillips screw
    • Remove the fan from the lower case.
    • If you are replacing the fan, transfer the pieces of EMI tape to your new fan before installation.
    • If present, remove the two pieces of tape covering the cables routed near the USB and power board.
    • Use a pair of tweezers to pull the internal display switch cable straight away from its socket on the USB and power board.
    • Peel and de-route the SIM card ribbon cable from its channel on top of the underside of the battery compartment.
    • The SIM card ribbon cable is still connected to the USB and power board. Do not completely remove it yet.
    • Remove the single 3 mm Phillips screw that secures the USB and power board as well as the DC jack bracket to the lower case.
    • Lift the DC jack bracket up off the USB and power board.
    • Grasp the USB and power board from its left edge, nearest the ports side.
    • Remove the USB and power board straight away from its recess in the lower case, minding any cables that may get tangled.
    • Use your fingernail or the flat end of a spudger to flip up the retaining flap on the SIM card cable ZIF socket.
    • Pull the SIM card ribbon cable out of its socket.
    • Use the flat end of a spudger to gently push the power cable from its socket.
    • Be sure you are pushing on the cable, not the socket itself.
    • It is recommended to push the connector from both sides in a side-by-side rocking motion to dislodge it from its socket.
    • Pull the power ribbon cable out of its socket.
    • USB and power board remains.
まとめ
Walter Galan
576,239 ポイント
1,203のガイドは作成済み
コメント1件
Where to find this replacement board?
greenbubby - 返信
統計データを表示:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 11
今までの合計 4,515
