この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
The HP Media Center 876x is capable of receiving television service through its TV tuner card. If you are unable to receive proper service, the TV tuner card may require replacement.
必要な工具と部品
Identify the TV tuner card (distal from the cooling fan, in the lower-left corner of the tower).
Using a #0 Phillips head screwdriver, remove the one (6 mm) screw fastening the TV tuner card into its slot.
ある他の人がこのガイドを完成しました。
