メインコンテンツにスキップ
HP Media Center 876x Optical Drive Replacement
必要な工具と部品
  1. HP Media Center 876x Optical Drive Replacement, Side Panel: 手順 1、 2の画像 1 HP Media Center 876x Optical Drive Replacement, Side Panel: 手順 1、 2の画像 2
    • Remove the two (9 mm) hand screws on the back panel.
  2. HP Media Center 876x Optical Drive Replacement: 手順 2、 3の画像 1 HP Media Center 876x Optical Drive Replacement: 手順 2、 3の画像 2 HP Media Center 876x Optical Drive Replacement: 手順 2、 3の画像 3
    • Place the tower on its side.
    • Slide the side panel horizontally to detach, and pull upward to remove.
  3. HP Media Center 876x Optical Drive Replacement, Front Cover: 手順 3、 2の画像 1 HP Media Center 876x Optical Drive Replacement, Front Cover: 手順 3、 2の画像 2
    • Orient the tower vertically.
    • Using the #0 Phillips head screwdriver, unscrew and remove the two (5 mm) screws that fasten the remaining side panel to the tower.
    • Slide the side panel out of its notches, and pull it gently off of the tower.
  4. HP Media Center 876x Optical Drive Replacement: 手順 4、 1の画像 1
    • Gently move the tower so that it is in the horizontal orientation.
    • Press down the black tabs (proximal to you) that fasten the front panel to the tower.
    • Press down on the distal, black tabs (symmetric with respect to the previous tabs).
    • Pull front panel forward slightly.
  5. HP Media Center 876x Optical Drive Replacement: 手順 5、 2の画像 1 HP Media Center 876x Optical Drive Replacement: 手順 5、 2の画像 2
    • The front panel will come off in a hinge-like fashion, exposing the drives underneath.
  6. HP Media Center 876x Optical Drive Replacement, Optical Drive: 手順 6、 3の画像 1 HP Media Center 876x Optical Drive Replacement, Optical Drive: 手順 6、 3の画像 2 HP Media Center 876x Optical Drive Replacement, Optical Drive: 手順 6、 3の画像 3
    • Identify the optical drive.
    • Pull the molex connectors out of the posterior end of the optical drive.
  7. HP Media Center 876x Optical Drive Replacement: 手順 7、 3の画像 1 HP Media Center 876x Optical Drive Replacement: 手順 7、 3の画像 2 HP Media Center 876x Optical Drive Replacement: 手順 7、 3の画像 3
    • Pull the ribbon cable out of the back of the optical drive.
  8. HP Media Center 876x Optical Drive Replacement: 手順 8、 3の画像 1 HP Media Center 876x Optical Drive Replacement: 手順 8、 3の画像 2 HP Media Center 876x Optical Drive Replacement: 手順 8、 3の画像 3
    • Using the Phillips #0 screwdriver, remove the two 5 mm screws that fasten the optical drive into its port.
    • Gently pull the optical drive through the front cavity.
  9. HP Media Center 876x Optical Drive Replacement: 手順 9、 2の画像 1 HP Media Center 876x Optical Drive Replacement: 手順 9、 2の画像 2
    • Remove the optical drive completely from its port.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Balakrishnan Pillai
メンバー登録日: 03/26/14
1,003 ポイント
8のガイドは作成済み
チーム
Clemson, Team 6-1, Benson Spring 2014 Clemson, Team 6-1, Benson Spring 2014人のメンバー
CLEM-BENSON-S14S6G1
3 メンバー
15のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 4
過去 30 日: 7
今までの合計 365
