メインコンテンツにスキップ
HP LaserJet P1102w Drive Belt Replacement
必要な工具と部品
  1. HP LaserJet P1102w Drive Belt Replacement, Left Side Panel: 手順 1、 3の画像 1 HP LaserJet P1102w Drive Belt Replacement, Left Side Panel: 手順 1、 3の画像 2 HP LaserJet P1102w Drive Belt Replacement, Left Side Panel: 手順 1、 3の画像 3
    • Flip printer on it's back. Using the plastic spudger, pry off front panel. There will be two main points to focus as shown.
    • Pry carefully to not break any plastic.
    my two main points were precisely under the rubber feet, they were surprisingly difficulty to dislodge.
    Peter Taffs - 返信
  2. HP LaserJet P1102w Drive Belt Replacement: 手順 2、 2の画像 1 HP LaserJet P1102w Drive Belt Replacement: 手順 2、 2の画像 2
    • Now that the pry points are free lift up the front panel.
  3. HP LaserJet P1102w Drive Belt Replacement: 手順 3、 2の画像 1 HP LaserJet P1102w Drive Belt Replacement: 手順 3、 2の画像 2
    • Unscrew the #1 Phillips screw 6mm on the back of the printer.
  4. HP LaserJet P1102w Drive Belt Replacement: 手順 4、 3の画像 1 HP LaserJet P1102w Drive Belt Replacement: 手順 4、 3の画像 2 HP LaserJet P1102w Drive Belt Replacement: 手順 4、 3の画像 3
    • Using the plastic spudger, remove the button housing from the top left of printer.
  5. HP LaserJet P1102w Drive Belt Replacement: 手順 5、 2の画像 1 HP LaserJet P1102w Drive Belt Replacement: 手順 5、 2の画像 2
    • Once the housing is removed, remove the three buttons.
  6. HP LaserJet P1102w Drive Belt Replacement: 手順 6、 3の画像 1 HP LaserJet P1102w Drive Belt Replacement: 手順 6、 3の画像 2 HP LaserJet P1102w Drive Belt Replacement: 手順 6、 3の画像 3
    • Use the plastic spudger to remove the side panel. There are three main prying points as shown.
    mine had a PH2 screw on the printer back thru the side panel into the aluminum serial plate/back, placed in the 2nd and third picture in the tab with a round screw hole and square locator hole. Critical clips were center back, center top and center bottom, and two points on the front.
    Peter Taffs - 返信
    edit, i see the screws talked about in step 3. sorry.
    Peter Taffs - 返信
  7. HP LaserJet P1102w Drive Belt Replacement: 手順 7、 2の画像 1 HP LaserJet P1102w Drive Belt Replacement: 手順 7、 2の画像 2
    • With all pry points free, remove the side panel.
  8. HP LaserJet P1102w Drive Belt Replacement, Drive Belt: 手順 8、 3の画像 1 HP LaserJet P1102w Drive Belt Replacement, Drive Belt: 手順 8、 3の画像 2 HP LaserJet P1102w Drive Belt Replacement, Drive Belt: 手順 8、 3の画像 3
    • Refer to the prerequisite guide to take off the front panel off.
    • With a #1 Phillips screwdriver remove only the top Phillips 60mm screw.
    • With the spudger pry the side panel off. There will be four flanges to unhitch.
  9. HP LaserJet P1102w Drive Belt Replacement: 手順 9、 2の画像 1 HP LaserJet P1102w Drive Belt Replacement: 手順 9、 2の画像 2
    • With side panel removed, there will be four Phillips 60mm screws to unscrew using a #1 Phillips screwdriver.
  10. HP LaserJet P1102w Drive Belt Replacement: 手順 10、 3の画像 1 HP LaserJet P1102w Drive Belt Replacement: 手順 10、 3の画像 2 HP LaserJet P1102w Drive Belt Replacement: 手順 10、 3の画像 3
    この手順で使用する道具:
    • Remove top two big gears using tweezers.
    • Take note of gear placement.
  11. HP LaserJet P1102w Drive Belt Replacement: 手順 11、 3の画像 1 HP LaserJet P1102w Drive Belt Replacement: 手順 11、 3の画像 2 HP LaserJet P1102w Drive Belt Replacement: 手順 11、 3の画像 3
    • With the #1 Phillips screwdriver remove the 60mm Phillips screw holding the belt tension-er.
    • With the screw removed, pull tension-er out.
    • Use tweezers to remove the loose drive belt.
    Que dois je faire si mon imprimante fait beaucoup de bruit en imprimant et que la totalité de feuille imprimée ne sort pas?
    anelka VILPIGUE - 返信
終わりに
6 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Jerome Etten
メンバー登録日: 10/04/18
730 ポイント
4のガイドは作成済み
チーム
UW Stout, Team S6-G4, Ogden Fall 2018 UW Stout, Team S6-G4, Ogden Fall 2018人のメンバー
UWSTOUT-OGDEN-F18S6G4
4 メンバー
10のガイドは作成済み
2 件のコメント
the tight side panel clips make this a difficult procedure, so take care both disassembling and assembling, for example make sure the power button is aligned with the level components behind before you push to clip the front home, as misalignment can break or dislocate internal parts.
Peter Taffs - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 29
過去 30 日: 135
今までの合計 3,368
