必要な工具と部品
Turn the device over so that the bottom side is facing up and the battery is facing away from you.
Use the Phillips #1 Screw Driver to unscrew the 6mm screw from the Wi-Fi Card Panel.
Lift off the Wi-Fi card panel off using the opposite hand.
もう少しです!
終わりに
2 の人々がこのガイドを完成させました。
