メインコンテンツにスキップ
HP HDX 16-1160US Keyboard Replacement
必要な工具と部品
  1. HP HDX 16-1160US Keyboard Replacement, Battery: 手順 1、 1の画像 1
    • Turn the device over so that the bottom side is facing up and the battery is facing away from you.
  2. HP HDX 16-1160US Keyboard Replacement: 手順 2、 3の画像 1 HP HDX 16-1160US Keyboard Replacement: 手順 2、 3の画像 2 HP HDX 16-1160US Keyboard Replacement: 手順 2、 3の画像 3
    • Locate the slider under the right side of the battery.
    • Using your thumb, slide it all the way to the left until the front of the battery lifts up.
  3. HP HDX 16-1160US Keyboard Replacement: 手順 3、 1の画像 1
    • With your thumb still holding the slider to the left, use the opposite hand to lift the battery out, removing it from the computer.
  4. HP HDX 16-1160US Keyboard Replacement, Keyboard: 手順 4、 1の画像 1
    • Remove the three 4mm screws using Phillips #1 screw driver.
    • Remove the four 6mm screws using Phillips #1 screw driver.
    • Remove the two 3mm screws using Phillips #1 screw driver.
  5. HP HDX 16-1160US Keyboard Replacement: 手順 5、 1の画像 1
    • Using your fingers, pry off the speaker cover.
  6. HP HDX 16-1160US Keyboard Replacement: 手順 6、 3の画像 1 HP HDX 16-1160US Keyboard Replacement: 手順 6、 3の画像 2 HP HDX 16-1160US Keyboard Replacement: 手順 6、 3の画像 3
    • Use the plastic opener to pry up the chrome keyboard cover from the lab top itself. Carefully work around the edges by prying each snap individually.
    • Remove the chrome keyboard cover.
    • Be careful not to pull the chrome cover completely off because there is a black strip connecting it to the laptop itself.
  7. HP HDX 16-1160US Keyboard Replacement: 手順 7、 3の画像 1 HP HDX 16-1160US Keyboard Replacement: 手順 7、 3の画像 2 HP HDX 16-1160US Keyboard Replacement: 手順 7、 3の画像 3
    • Locate and remove the two 4mm screws with the Phillips #1 screw driver.
  8. HP HDX 16-1160US Keyboard Replacement: 手順 8、 2の画像 1 HP HDX 16-1160US Keyboard Replacement: 手順 8、 2の画像 2
    • Using your hands, pull the keyboard out.
    • Do not pull completely off because there is a grey strip connecting it to the laptop itself.
  9. HP HDX 16-1160US Keyboard Replacement: 手順 9、 2の画像 1 HP HDX 16-1160US Keyboard Replacement: 手順 9、 2の画像 2
    • Lift the black tab using the plastic opening tool.
    • Gently pull the grey strip out, horizontally way from you. This will release the keyboard from the computer.
終わりに
2 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Daniel McBroom
メンバー登録日: 04/14/14
278 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 12-38, Maness Spring 2014 Cal Poly, Team 12-38, Maness Spring 2014人のメンバー
CPSU-MANESS-S14S12G38
4 メンバー
5のガイドは作成済み
2 件のコメント
Hello Daniel,
Hoping you might be able to assist me with the similar HDX18 -1000 CTO Premium Notebook / FW314AV Pavilion .
Interested in replacing the LCD inverter board, and would like to confirm where its located and if the HDX 18 has one or two installed.
Your time and any assistance is greatly appreciated, thank you.
AppGuy - 返信
Link to HP HDX 16 Entertainment PC Maintenance and Service Guide: Document Part Number: 487263-001;
http://h10032.www1.hp.com/ctg/Manual/c01...
AppGuy - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 14
今までの合計 2,327
