必要な工具と部品
Turn the device over so that the bottom side is facing up and the battery is facing away from you.
Remove the three 4mm screws using Phillips #1 screw driver.
Remove the four 6mm screws using Phillips #1 screw driver.
Remove the two 3mm screws using Phillips #1 screw driver.
もう少しです!
終わりに
3 の人々がこのガイドを完成させました。
