メインコンテンツにスキップ
HP HDX 16-1160US DVD Drive Replacement
必要な工具と部品
  1. HP HDX 16-1160US DVD Drive Replacement, Battery: 手順 1、 1の画像 1
    • Turn the device over so that the bottom side is facing up and the battery is facing away from you.
  2. HP HDX 16-1160US DVD Drive Replacement: 手順 2、 3の画像 1 HP HDX 16-1160US DVD Drive Replacement: 手順 2、 3の画像 2 HP HDX 16-1160US DVD Drive Replacement: 手順 2、 3の画像 3
    • Locate the slider under the right side of the battery.
    • Using your thumb, slide it all the way to the left until the front of the battery lifts up.
  3. HP HDX 16-1160US DVD Drive Replacement: 手順 3、 1の画像 1
    • With your thumb still holding the slider to the left, use the opposite hand to lift the battery out, removing it from the computer.
  4. HP HDX 16-1160US DVD Drive Replacement, Keyboard: 手順 4、 1の画像 1
    • Remove the three 4mm screws using Phillips #1 screw driver.
    • Remove the four 6mm screws using Phillips #1 screw driver.
    • Remove the two 3mm screws using Phillips #1 screw driver.
  5. HP HDX 16-1160US DVD Drive Replacement: 手順 5、 1の画像 1
    • Using your fingers, pry off the speaker cover.
  6. HP HDX 16-1160US DVD Drive Replacement: 手順 6、 3の画像 1 HP HDX 16-1160US DVD Drive Replacement: 手順 6、 3の画像 2 HP HDX 16-1160US DVD Drive Replacement: 手順 6、 3の画像 3
    • Use the plastic opener to pry up the chrome keyboard cover from the lab top itself. Carefully work around the edges by prying each snap individually.
    • Remove the chrome keyboard cover.
    • Be careful not to pull the chrome cover completely off because there is a black strip connecting it to the laptop itself.
  7. HP HDX 16-1160US DVD Drive Replacement: 手順 7、 3の画像 1 HP HDX 16-1160US DVD Drive Replacement: 手順 7、 3の画像 2 HP HDX 16-1160US DVD Drive Replacement: 手順 7、 3の画像 3
    • Locate and remove the two 4mm screws with the Phillips #1 screw driver.
  8. HP HDX 16-1160US DVD Drive Replacement: 手順 8、 2の画像 1 HP HDX 16-1160US DVD Drive Replacement: 手順 8、 2の画像 2
    • Using your hands, pull the keyboard out.
    • Do not pull completely off because there is a grey strip connecting it to the laptop itself.
  9. HP HDX 16-1160US DVD Drive Replacement: 手順 9、 2の画像 1 HP HDX 16-1160US DVD Drive Replacement: 手順 9、 2の画像 2
    • Lift the black tab using the plastic opening tool.
    • Gently pull the grey strip out, horizontally way from you. This will release the keyboard from the computer.
  10. HP HDX 16-1160US DVD Drive Replacement, DVD Drive: 手順 10、 1の画像 1
    • Use the Phillips #1 Screw Driver to unscrew the 5mm screw.
  11. HP HDX 16-1160US DVD Drive Replacement: 手順 11、 1の画像 1
    • Flip over the device so that the bottom side is facing up.
    • Use the Phillips #1 Screw Driver to unscrew the 7mm screw near the center of the device.
  12. HP HDX 16-1160US DVD Drive Replacement: 手順 12、 1の画像 1
    • Push down and pull out the DVD on the left side of the device.
終わりに
3 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Marshall Reid
メンバー登録日: 04/14/14
527 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 12-38, Maness Spring 2014 Cal Poly, Team 12-38, Maness Spring 2014人のメンバー
CPSU-MANESS-S14S12G38
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 11
今までの合計 1,449
