はじめに
Make sure you have a compatible DVD drive with the same dimensions.
必要な工具と部品
この手順で使用する道具:Anti-Static Wrist Strap$7.95
Ground yourself by either touching an unpainted metal surface or by using the Anti-Static wrist strap.
Turn off the computer and remove the charger from the charging port.
Turn the laptop over and slide the battery release catch to the right. The battery will pop up from its slot. Remove it using your fingers.
もう少しです!
終わりに
