メインコンテンツにスキップ
HP G62 347NR Keyboard Replacement
必要な工具と部品
  1. HP G62 347NR Keyboard Replacement, Keyboard: 手順 1、 1の画像 1
    • Make sure the device is turned off before removing the battery to avoid loss or corruption of files.
    • Turn the device over so the bottom is facing up.
    • Slide the battery release to the left until you hear a click.
    • Once you hear a click, the battery will have been released from the battery compartment.
  2. HP G62 347NR Keyboard Replacement: 手順 2、 1の画像 1
    • Remove the battery, carefully, from the compartment.
  3. HP G62 347NR Keyboard Replacement: 手順 3、 2の画像 1 HP G62 347NR Keyboard Replacement: 手順 3、 2の画像 2
    • Find the hard drive compartment with two Phillips head screws.
    • Use the PH1 screwdriver to loosen and remove both screws.
    • Gently remove the hard drive compartment.
  4. HP G62 347NR Keyboard Replacement: 手順 4、 2の画像 1 HP G62 347NR Keyboard Replacement: 手順 4、 2の画像 2
    • Locate the three Phillips head screws on the compartment with the wifi and keyboard logos.
    • Using the Phillips #1 screwdriver, remove the three screws.
  5. HP G62 347NR Keyboard Replacement: 手順 5、 2の画像 1 HP G62 347NR Keyboard Replacement: 手順 5、 2の画像 2
    • Locate the two keyboard logos on back of the computer.
    • Find the Phillips head screws in the hole next to the logo.
    • Remove the two screws using a Phillips #1 screwdriver.
  6. HP G62 347NR Keyboard Replacement: 手順 6、 2の画像 1 HP G62 347NR Keyboard Replacement: 手順 6、 2の画像 2
    • In the battery compartment, locate the three keyboard logos.
    • Find the Phillips head screws next to each logo.
    • Remove the three screws using the Phillips #1 screwdriver.
  7. HP G62 347NR Keyboard Replacement: 手順 7、 2の画像 1 HP G62 347NR Keyboard Replacement: 手順 7、 2の画像 2
    • Place the plastic opening tool between the keyboard and the motherboard.
    • Gently pry the entire keyboard up and away from the laptop's motherboard.
    • Once you have part of the keyboard separated, run your fingers around the edge of the keyboard to separate the entire thing.
終わりに
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
McKenzi Morris
メンバー登録日: 10/10/16
511 ポイント
3のガイドは作成済み
チーム
Texas Tech, Team 6-1, Bennett Fall 2016 Texas Tech, Team 6-1, Bennett Fall 2016人のメンバー
TTU-BENNETT-F16S6G1
3 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 23
今までの合計 2,823
