1. First, remove the battery to avoid electric shock
    • First, remove the battery to avoid electric shock
    • Slide and unlock the battery, then lift it
  2. Now, you should to remove the Wi-Fi card cover
    • Now, you should to remove the Wi-Fi card cover
    • Remove this screw
    • Lift the cover
    • The Wi-Fi card is locked, but you should to change that.
    • Remove this two little screws.
    • Pull the Wi-Fi card.
    • You should to be carefull with the next steps, the plugs are easy to separate, but they are fragile
    • Pull carefully both cables from the Wi-Fi card, it requires a little strength
    • Now it's time to put the new Wi-Fi card
    • Connect both plugs, the cable with white tag, at the left of the Wi-Fi card, the green one, at the right plug
    • The Wi-Fi card already has the power plugs, now it's time to the data plug
    • Insert the Wi-Fi card in a 45 degrees angle
    • Now press it and screw it
    • For finish, reassemble the cover
    • If the cover is still lifted, press softly until you hear a click
ゴール
4 の人々がこのガイドを完成させました。
jimenezser
メンバー登録日: 2012年08月29日
3,514 ポイント
4のガイドは作成済み
If the button that turns blue when I start my computer stays orange does that mean I need to install a new wifi card?
veronica - 返信
Hi frnd just want to know ur hp laptop button was not working it stayed orange thn what did u do? U changed wifi card or button plz reply me i have same condition can u ans me on my mobile whatsapp plz +85254077440
saqib raheem -
Please provide information on the model of the wifi card
thaisabs - 返信
My card wifi on laptop G60-530US was not working. Can you suggest me some modle of new card wifi which can be suitable my laptop. Thanks so much
tech - 返信
統計データを表示:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 20
今までの合計 2,981
