メインコンテンツにスキップ
HP Folio 13t-1000 Audio Speakers Replacement
必要な工具と部品
  1. HP Folio 13t-1000 Audio Speakers Replacement, Keyboard: 手順 1、 2の画像 1 HP Folio 13t-1000 Audio Speakers Replacement, Keyboard: 手順 1、 2の画像 2
    • Use an antistatic wrist wrap, or periodically touch unpainted metal to minimize the risk of damaging the laptop by electrostatic shock.
    • Use a PH1 screw head to remove the 16, 6mm screws from the bottom case housing of the laptop.
  2. HP Folio 13t-1000 Audio Speakers Replacement: 手順 2、 3の画像 1 HP Folio 13t-1000 Audio Speakers Replacement: 手順 2、 3の画像 2 HP Folio 13t-1000 Audio Speakers Replacement: 手順 2、 3の画像 3
    • This step requires unlocking the very fragile plastic clips along the frame; take care not to damage them.
    • Slide the spudger with a twisting motion along the entire perimeter of the laptop until the top cover is separated from the frame of the device.
  3. HP Folio 13t-1000 Audio Speakers Replacement: 手順 3、 1の画像 1
    • Using the flat portion of the plastic spudger, push the corner of the black surface until the first clip unlocks.
    • The top right corner of the keyboard should now be sticking out slightly.
    • Repeat the same process for the top left corner.
  4. HP Folio 13t-1000 Audio Speakers Replacement: 手順 4、 2の画像 1 HP Folio 13t-1000 Audio Speakers Replacement: 手順 4、 2の画像 2
    • Slide the keyboard up and towards the screen just enough to separate the keyboard from the top cover.
  5. HP Folio 13t-1000 Audio Speakers Replacement: 手順 5、 3の画像 1 HP Folio 13t-1000 Audio Speakers Replacement: 手順 5、 3の画像 2 HP Folio 13t-1000 Audio Speakers Replacement: 手順 5、 3の画像 3
    • To unlock the clamps connected to the motherboard, use your fingers or insert the pointed edge of the spudger between the first clamp and the cable.
    • Repeat the same process for the second clamp.
  6. HP Folio 13t-1000 Audio Speakers Replacement: 手順 6、 3の画像 1 HP Folio 13t-1000 Audio Speakers Replacement: 手順 6、 3の画像 2 HP Folio 13t-1000 Audio Speakers Replacement: 手順 6、 3の画像 3
    • Remove the keyboard from the laptop.
  7. HP Folio 13t-1000 Audio Speakers Replacement, Top Hardware Cover: 手順 7、 3の画像 1 HP Folio 13t-1000 Audio Speakers Replacement, Top Hardware Cover: 手順 7、 3の画像 2 HP Folio 13t-1000 Audio Speakers Replacement, Top Hardware Cover: 手順 7、 3の画像 3
    • Place your finger between one of the plastic clamps and the cable and apply a slight leveraging force until the clamp pops up.
    • Do the same for the second connection.
  8. HP Folio 13t-1000 Audio Speakers Replacement: 手順 8、 2の画像 1 HP Folio 13t-1000 Audio Speakers Replacement: 手順 8、 2の画像 2
    • Remove the top hardware cover.
  9. HP Folio 13t-1000 Audio Speakers Replacement, Audio Speakers: 手順 9、 1の画像 1
    • For the left speaker, use the PH1 screw head to remove the 2 screws.
  10. HP Folio 13t-1000 Audio Speakers Replacement: 手順 10、 2の画像 1 HP Folio 13t-1000 Audio Speakers Replacement: 手順 10、 2の画像 2
    • Carefully unplug the connection to the motherboard using your finger or the nylon spudger.
  11. HP Folio 13t-1000 Audio Speakers Replacement: 手順 11、 3の画像 1 HP Folio 13t-1000 Audio Speakers Replacement: 手順 11、 3の画像 2 HP Folio 13t-1000 Audio Speakers Replacement: 手順 11、 3の画像 3
    • Carefully remove and replace the left speaker.
  12. HP Folio 13t-1000 Audio Speakers Replacement: 手順 12、 1の画像 1
    • For the right speaker, use the PH1 screw head to remove the 2 screws.
  13. HP Folio 13t-1000 Audio Speakers Replacement: 手順 13、 1の画像 1
    • Move aside the black and white wires that are channeled through the top of the speaker housing using your fingers.
  14. HP Folio 13t-1000 Audio Speakers Replacement: 手順 14、 2の画像 1 HP Folio 13t-1000 Audio Speakers Replacement: 手順 14、 2の画像 2
    • Unplug the connection to the motherboard using your fingers or the nylon spudger.
  15. HP Folio 13t-1000 Audio Speakers Replacement: 手順 15、 1の画像 1
    • Carefully remove and replace the right speaker.
終わりに
作成者
2人の作成者と共同で作成されました。
Josh Rollins
メンバー登録日: 09/28/16
131 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 1-2, Cagle Fall 2016 USF Tampa, Team 1-2, Cagle Fall 2016人のメンバー
USFT-CAGLE-F16S1G2
4 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 8
今までの合計 279
