メインコンテンツにスキップ
HP Flyer Red Keyboard Replacement
必要な工具と部品
  1. HP Flyer Red Keyboard Replacement, Battery: 手順 1、 2の画像 1 HP Flyer Red Keyboard Replacement, Battery: 手順 1、 2の画像 2
    • Make sure your laptop is powered off.
    • With laptop closed flip to look at the underside of the laptop.
  2. HP Flyer Red Keyboard Replacement: 手順 2、 1の画像 1
    • On the underside of the laptop towards the hinge for the screen there are two rectangular slide switches located inside of rectangular tracks.
  3. HP Flyer Red Keyboard Replacement: 手順 3、 2の画像 1 HP Flyer Red Keyboard Replacement: 手順 3、 2の画像 2
    • The left switch is the battery unlock switch.
    • Inside the rectangular track of this switch there is an image of a closed lock that should be visible. Push this switch to the other end of the track and an image of an open lock should be visible.
  4. HP Flyer Red Keyboard Replacement: 手順 4、 1の画像 1
    • Then take and slide the other switch to the other end of its track which will pop out the battery.
    • Grab the battery and pull it out of the slot.
  5. HP Flyer Red Keyboard Replacement, Keyboard: 手順 5、 2の画像 1 HP Flyer Red Keyboard Replacement, Keyboard: 手順 5、 2の画像 2
    • Next locate and unscrew the two 4mm Phllips #1 screws with the keyboard symbol located towards the middle and top of the bottom of the laptop.
  6. HP Flyer Red Keyboard Replacement: 手順 6、 3の画像 1 HP Flyer Red Keyboard Replacement: 手順 6、 3の画像 2 HP Flyer Red Keyboard Replacement: 手順 6、 3の画像 3
    • Next turn the laptop over and flip open the screen.
    • Use the plastic opening tool to pry the keyboard upwards from the bottom right hand corner of the keyboard.
    • Use another plastic opening tool with the first plastic opening tool you placed to undo every plastic clasp surrounding the keyboard.
  7. HP Flyer Red Keyboard Replacement: 手順 7、 3の画像 1 HP Flyer Red Keyboard Replacement: 手順 7、 3の画像 2 HP Flyer Red Keyboard Replacement: 手順 7、 3の画像 3
    • Next lift up the keyboard gently and use the plastic opening tool to undo the ribbon wire by unclasping the ZIF (zero insertion force) connector to the laptop.
    • Gently slide the ribbon wire out of its slot.
終わりに
7 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Anthony Ciotti
メンバー登録日: 04/07/16
747 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team 4-5, Catania Spring 2016 UMass Dartmouth, Team 4-5, Catania Spring 2016人のメンバー
UMASSD-CATANIA-S16S4G5
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 2,196
