メインコンテンツにスキップ
HP Envy x360 m6-aq103dx Hard drive Replacement
必要な工具と部品
  1. HP Envy x360 m6-aq103dx Hard drive Replacement, Bottom Cover: 手順 1、 3の画像 1 HP Envy x360 m6-aq103dx Hard drive Replacement, Bottom Cover: 手順 1、 3の画像 2 HP Envy x360 m6-aq103dx Hard drive Replacement, Bottom Cover: 手順 1、 3の画像 3
    • Flip the laptop over to expose the underside.
    • Remove the two grip pads with blue plastic opening tool by inserting the tool between the laptop and the pads and slowly lifting up.
    • The grip pads are tacky, remove slowly to avoid separating the adhesive.
  2. HP Envy x360 m6-aq103dx Hard drive Replacement: 手順 2、 1の画像 1
    • Remove the two 8 mm Phillips Head screws that were under the grip pads using a Phillip's Head 1 Screwdriver.
  3. HP Envy x360 m6-aq103dx Hard drive Replacement: 手順 3、 1の画像 1
    • Remove the six 5 mm Torx screws using a T5 Torx Screwdriver.
  4. HP Envy x360 m6-aq103dx Hard drive Replacement: 手順 4、 3の画像 1 HP Envy x360 m6-aq103dx Hard drive Replacement: 手順 4、 3の画像 2 HP Envy x360 m6-aq103dx Hard drive Replacement: 手順 4、 3の画像 3
    • Use the nylon spudger to pop off the bottom cover by inserting it into the heat vent and twisting to the left or right.
    • You may hear a slight clicking or popping, but that is normal.
  5. HP Envy x360 m6-aq103dx Hard drive Replacement, Hard Drive: 手順 5、 3の画像 1 HP Envy x360 m6-aq103dx Hard drive Replacement, Hard Drive: 手順 5、 3の画像 2 HP Envy x360 m6-aq103dx Hard drive Replacement, Hard Drive: 手順 5、 3の画像 3
    • Disconnect the ribbon cable with the purple tag by flipping the black tab with the plastic opening tool.
    • Disconnect the ribbon cable by gently pulling it away from the connector with your fingers.
  6. HP Envy x360 m6-aq103dx Hard drive Replacement: 手順 6、 3の画像 1 HP Envy x360 m6-aq103dx Hard drive Replacement: 手順 6、 3の画像 2 HP Envy x360 m6-aq103dx Hard drive Replacement: 手順 6、 3の画像 3
    • Remove the two Phillips head screws (5 mm) using the Phillip's head #1 screwdriver.
    • Use your hands to lift the hard drive up and remove it.
終わりに
5 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Jordan Eremeyeff
メンバー登録日: 10/01/17
597 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team S4-G3, Livingston Fall 2017 Cal Poly, Team S4-G3, Livingston Fall 2017人のメンバー
CPSU-LIVINGSTON-F17S4G3
4 メンバー
9のガイドは作成済み
コメント 1 件
Great guide. Only thing i did different was not removing the ribbon cable. It’s not necessary. Just unscrew the hard drive enclosure and you’ll have plenty of room to disconnect the sata connector plugged in to the drive.
Ron H - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 30
今までの合計 7,117
