はじめに
Is the hard drive on you HP Envy x360 m6-aq103dx acting up or not working correctly? Follow this simple guide to replace the hard drive. You'll need a plastic opening tool and a Phillips Head #1 screwdriver.
必要な工具と部品
Flip the laptop over to expose the underside.
Remove the two grip pads with blue plastic opening tool by inserting the tool between the laptop and the pads and slowly lifting up.
Disconnect the ribbon cable with the purple tag by flipping the black tab with the plastic opening tool.
Disconnect the ribbon cable by gently pulling it away from the connector with your fingers.
5 の人々がこのガイドを完成させました。
