はじめに
If you want to change out your for your HP Envy x360 m Convertible (Model 15m-cn0012dx), use this guide to replace the hard drive.
If you are running low on space, updating a hard drive with a larger drive can give you more space, and could also speed up your computer.
必要な工具と部品
Set the laptop face down.
Peel back the grey screw guards, along the top and bottom edge of the back case. It may be helpful to use a spudger to get started.
ある他の人がこのガイドを完成しました。
