メインコンテンツにスキップ
HP Envy x360 15m-cn0012dx Fan Replacement
必要な工具と部品
  1. HP Envy x360 15m-cn0012dx  Fan Replacement, Fan: 手順 1、 2の画像 1 HP Envy x360 15m-cn0012dx  Fan Replacement, Fan: 手順 1、 2の画像 2
    • Make sure the computer is turned off, and remove all cables.
    • Set the laptop face down.
    • Peel back the grey screw guards, along the top and bottom edge of the back case. It may be helpful to use a spudger to get started.
    • Peel slowly to avoid tearing the rubber covers.
  2. HP Envy x360 15m-cn0012dx  Fan Replacement: 手順 2、 3の画像 1 HP Envy x360 15m-cn0012dx  Fan Replacement: 手順 2、 3の画像 2 HP Envy x360 15m-cn0012dx  Fan Replacement: 手順 2、 3の画像 3
    • Using the Phillips #0 screwdriver, remove the seven 5mm screws from the back case.
  3. HP Envy x360 15m-cn0012dx  Fan Replacement: 手順 3、 3の画像 1 HP Envy x360 15m-cn0012dx  Fan Replacement: 手順 3、 3の画像 2 HP Envy x360 15m-cn0012dx  Fan Replacement: 手順 3、 3の画像 3
    • Pry open the back cover using the iFixit Opening Tool.
    • While using the tool, place a pick at each corner of the computer (be careful and do it slowly).
    • Once all the corners are slightly lifted, carefully pop off the back cover.
  4. HP Envy x360 15m-cn0012dx  Fan Replacement: 手順 4、 3の画像 1 HP Envy x360 15m-cn0012dx  Fan Replacement: 手順 4、 3の画像 2 HP Envy x360 15m-cn0012dx  Fan Replacement: 手順 4、 3の画像 3
    • Remove the two 4mm screws from the fan using a Phillips #0 screwdriver.
    • Peel the tape off of the multicolor cable bundle connecting the fan to the motherboard.
    • Use the iFixit opening tool to disconnect the connector.
  5. HP Envy x360 15m-cn0012dx  Fan Replacement: 手順 5、 2の画像 1 HP Envy x360 15m-cn0012dx  Fan Replacement: 手順 5、 2の画像 2
    • Peel back the tape from the heatsink.
    • Use the Phillips #0 screwdriver to remove the four captive screws from the heatsink.
    • These screws will stay inside the heatsink while it is removed, simply loosen them until they disengage from the case and the heatsink becomes loose.
  6. HP Envy x360 15m-cn0012dx  Fan Replacement: 手順 6、 2の画像 1 HP Envy x360 15m-cn0012dx  Fan Replacement: 手順 6、 2の画像 2
    • Unlatch the black cable from the plastic guides on the fan.
    • Lift the fan from the laptop case.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Ross Jeseritz
メンバー登録日: 02/04/20
157 ポイント
1ガイドが承認済み
チーム
UW Stout, Team S1-G3, Schneider-Bateman Spring 2020 UW Stout, Team S1-G3, Schneider-Bateman Spring 2020人のメンバー
UWSTOUT-SCHNEIDER-BATEMAN-S20S1G3
3 メンバー
5のガイドは作成済み
コメント 1 件
You didn't show how to remove the Fan. You removed the Fan and Heat Sink. There's 4 more screws. Finish the job.
philw395 - 返信
コメントを追加
統計データ:
過去 24時間: 8
過去 7 日: 20
過去 30 日: 67
今までの合計 2,843
